Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I had gotten a Petronix electronic ignition module (1847V). Prior to installing it, the car had been running great with the points (I know, should have left well enough alone). I installed it per the instructions and cranked the motor over but nothing. I checked all my connections and cranked it over again and nothing. So I removed it and put the points back on.
When I go to start it, it seems that only 2 of the cylinders are firing. It was definitely idling low. My CHT gauge never really moved (it's on #3) so I suspect that 3 and possibly 4 are not firing. I drove it about 1/4 mile and no power. Could I have flooded 3 and 4 when I had the Petronix unit on? I'm going to let the car sit overnight and try it again in the morning. Could I have damaged something with the Petronix unit? |
Cevan |
I re-checked all the vacuum lines and electrical connections and everything looks good. The coil measured 4.3 ohms between pin 1 and 15 on the coil and it measured 8.21 k ohms between the tower and pin 1.
I pulled the plugs. #1 and #2 look fine. #3 and #4 looked fouled, covered in fuel and the cylinders smelled of unburnt fuel. I cleaned up the plugs and checked for spark on #3 and #4 and they are. So given that the injectors appear to be providing fuel and the plugs are getting juice, can I conclude that #3 and #4 flooded when trying the Petronix unit and never recovered? I plan to leave the plugs out tonight to allow the gas to evaporate and to put them back in tomorrow night. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:27 PM |
