Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I had gotten a Petronix electronic ignition module (1847V). Prior to installing it, the car had been running great with the points (I know, should have left well enough alone). I installed it per the instructions and cranked the motor over but nothing. I checked all my connections and cranked it over again and nothing. So I removed it and put the points back on.
When I go to start it, it seems that only 2 of the cylinders are firing. It was definitely idling low. My CHT gauge never really moved (it's on #3) so I suspect that 3 and possibly 4 are not firing. I drove it about 1/4 mile and no power. Could I have flooded 3 and 4 when I had the Petronix unit on? I'm going to let the car sit overnight and try it again in the morning. Could I have damaged something with the Petronix unit? |
Thack |
Member ![]() ![]() Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 ![]() |
I think you have somehow messed up the wiring to the coil or perhaps the ignition wires are not seated fully. Take off the number 3 or 4 wire at the plug and put an extra plug on the end and see if it fires. Ground the plug to the engine but try to attach it. If you hold the plug it will shock you. If you get a full blue spark then you have a fuel or trigger points issue. No spark, then you can work back from there.
Cevan |
I think you have somehow messed up the wiring to the coil or perhaps the ignition wires are not seated fully. Take off the number 3 or 4 wire at the plug and put an extra plug on the end and see if it fires. Ground the plug to the engine but try to attach it. If you hold the plug it will shock you. If you get a full blue spark then you have a fuel or trigger points issue. No spark, then you can work back from there. When I took the #3 and #4 plugs out, I cleaned them with compressed air and then did as you suggested. Both #3 and #4 got spark. I didn't do anything to the coil wiring expect disconnect the green points wire when I installed the Pertronix. When I put the points back on, I plugged the green wire back in. Both #3 and #4 cylinders smalled of gas so I'm assuming the injectors are providing fuel. How do I check the trigger points? I will buy a timing light and dwell meter to check these as well. I'll also use my noid light to double check the injectors. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:39 PM |
