> Pilot bearing in the crank, is this going to be an issue?
VaccaRabite
post Mar 15 2008, 03:16 PM
En Garde!
Isn't this bearing supposed to be in the flywheel?
How do I get the bugger out?
What should I do here?
(IMG:http://farm4.static.flickr.com/3182/2335190315_28837f1729.jpg)
If it is not an issue, please let me know. Its in there pretty good. I figure I am going to have to weld a bolt to it to get it out. Right now, I have no purchase.
Zach
Cap'n Krusty
post Mar 28 2008, 12:42 PM
Cap'n Krusty
All this verbiage, and not much in the way of a real answer.. Two answers that should help you.
(A) Use a clutch pilot tool and pack the bearing with grease. Using a BFH, hit the sucker REALLY hard (might be wise to drape it with a shop rag). Repeat as necessary. Eventually, it'll come out. I've done literally hundreds of them this way, and it works just fine (unless the bearing has broken up). If you don't have a pilot tool, how do you center up the disc?
((IMG:style_emoticons/default/cool.gif) If you don't want to do that, drive it in a little, using a drift of just the right diameter so you don't damage the bearing. It's plenty greased up by now. Use a rag to remove as much of the excess grease as is feasible. Put a bearing in the flywheel, and don't forget the felt washer on the clutch side. You're mainshaft won't care about the old bearing., and the added weight won't slow you down all that much.
The T2s had the bearing in the crank, because the mainshaft is longer. Most T4 cars sold in the US were automatics, and the crank had a sleeve installed, probably for the centering stub on the torque converter. T2s with automatics have the same bushing.
It's likely that the T4 with a manual tranny had the bearing in the crank, too, but I've never seen one so I can't comment on that.
Now, go fix it! The Cap'n
Vacca Rabite   Pilot bearing in the crank   Mar 15 2008, 03:16 PM
brp986s   the pilot bearing goes in the flywheel, not the cr...   Mar 15 2008, 04:01 PM
SirAndy   the pilot bearing goes in the flywheel, not the c...   Mar 15 2008, 04:32 PM
McMark   Get some bearing grease and pack, pack, pack it in...   Mar 15 2008, 04:24 PM
Vacca Rabite   Anyone have a good reason not to just leave that ...   Mar 15 2008, 04:39 PM
brer   There is a spacer that goes in the crank and its n...   Mar 15 2008, 04:51 PM
BIGKAT_83   Get some bearing grease and pack, pack, pack it i...   Mar 15 2008, 05:13 PM
Mark Henry   Dude it comes out real easy. I use a autobody slid...   Mar 15 2008, 05:38 PM
Krieger914   Put a couple of bolts in the end of the fw and use...   Mar 15 2008, 09:12 PM
brer   +1 for grease and tight fitting rod, or better yet...   Mar 15 2008, 09:55 PM
LvSteveH   For what it's worth I had a car running dual p...   Mar 15 2008, 10:45 PM
davep   The 411, at least, had the bearing in the crank li...   Mar 16 2008, 08:30 AM
Gint   Seems like you could cut the cage with a saw blade...   Mar 16 2008, 08:57 AM
brer   there is also that felt washer that goes in. with...   Mar 16 2008, 09:59 AM
davep   Well, the bearing in his photo is not properly sea...   Mar 16 2008, 06:35 PM
Vacca Rabite   Well, I treid the grease trick last night to pop t...   Mar 28 2008, 11:58 AM
brer   you could have better luck putting some heat shrin...   Mar 28 2008, 12:09 PM
jkeyzer   this is one of those things where if you take a sh...   Mar 28 2008, 12:11 PM
Cap'n Krusty   All this verbiage, and not much in the way of a re...   Mar 28 2008, 12:42 PM
davep   It's likely that the T4 with a manual tranny ...   Mar 28 2008, 08:35 PM
Krieger914   Don't worry about it. If you put another bear...   Mar 28 2008, 02:32 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:23 PM
