Pilot bearing in the crank, is this going to be an issue? |
VaccaRabite |
Mar 15 2008, 03:16 PM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Isn't this bearing supposed to be in the flywheel?
How do I get the bugger out? What should I do here? (IMG:http://farm4.static.flickr.com/3182/2335190315_28837f1729.jpg) If it is not an issue, please let me know. Its in there pretty good. I figure I am going to have to weld a bolt to it to get it out. Right now, I have no purchase. Zach |
Krieger |
Mar 28 2008, 02:32 PM
Advanced Member Group: Members Posts: 4,759 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Don't worry about it. If you put another bearing in the flywheel it won't touch the one in your crank. The trans input shaft is tapered on the end. Here is a different "spin" on that extra bearing in the crank. It is insurance if the crank pilot bearing fails. I only had only one bearing in the crank and not the flywheel. It held that input shaft from really screwing up the tranny, but I had a constant oil leak because there was enough movement on the tranny seal.
Lo-Fi Version | Time is now: 31st October 2024 - 07:27 PM |
