Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I had gotten a Petronix electronic ignition module (1847V). Prior to installing it, the car had been running great with the points (I know, should have left well enough alone). I installed it per the instructions and cranked the motor over but nothing. I checked all my connections and cranked it over again and nothing. So I removed it and put the points back on.
When I go to start it, it seems that only 2 of the cylinders are firing. It was definitely idling low. My CHT gauge never really moved (it's on #3) so I suspect that 3 and possibly 4 are not firing. I drove it about 1/4 mile and no power. Could I have flooded 3 and 4 when I had the Petronix unit on? I'm going to let the car sit overnight and try it again in the morning. Could I have damaged something with the Petronix unit? |
Cevan |
Got it running!! It appears that #3 and #4 got flooded b/c now it runs.
I bought a dwell meter and timing light. I set the initial gap at .016 per the Haynes manual and my dwell was about 30 degrees, so I started to reduce the gap. I'm down to about .011 or .010 and it's up to 40 degrees. It seems like I'll have to get the gap down to almost nothing in order to see a dwell reading of 44-50 degrees. Does this sound right? |
Lo-Fi Version | Time is now: 25th June 2024 - 10:38 PM |
