Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I had gotten a Petronix electronic ignition module (1847V). Prior to installing it, the car had been running great with the points (I know, should have left well enough alone). I installed it per the instructions and cranked the motor over but nothing. I checked all my connections and cranked it over again and nothing. So I removed it and put the points back on.
When I go to start it, it seems that only 2 of the cylinders are firing. It was definitely idling low. My CHT gauge never really moved (it's on #3) so I suspect that 3 and possibly 4 are not firing. I drove it about 1/4 mile and no power. Could I have flooded 3 and 4 when I had the Petronix unit on? I'm going to let the car sit overnight and try it again in the morning. Could I have damaged something with the Petronix unit? |
Cevan |
I am a dumbass. I was looking at the 6 cylinder setting. Now my dwell is within spec. Now I have to bend an old 13 mm wrench to try and get at the bolt holding down the dizzy so I can check/adjust the timing. The damn vacuum advance prevents me from using one of my closed end flex wrench.
Thanks again for everyones help. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:17 PM |
