'7X 2.7-6 Projekt Thread, Updated 5/4/08 - IT IS ALIVE... well, sort of... |
KaptKaos |
Dec 17 2007, 12:05 AM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I finally got my car moved around in the back so that I can get it up onto jack stands and take a look around.
My short term goal is to get the oil changed, swap the gas tank, charge the battery and try and fire her up. I took a few steps towards that today. First, I was under there cleaning stuff up. I noticed this on the passenger side of the trans. I assume that it is the throttle cable, but being this is my first /6, I need to confirm. Secondly, I drained the oil from the case and the tank. For those that don't recall, here is my 911 tank, cut into the floor. Problem is that when I drained the case and the tank, I only got 1/2 gallon of oil. I was expecting about 3.5 gallons (14 qts +/-). Not even close. This is my first dry sump motor, so am I missing something? Here is a picture of the engine mount bar. I don't know if this is stock, custom, aftermarket or ??? A little help pls. The mount bar sits so low that the side shift trans rod is above it. Lastly, when I got the car, the PO said that he had buggered up the trans. Its a side shifter. I cleaned it up a little and took off the shift rod head and the ball socket. It's a new socket bushing which is nice. I was able to move the selector through all gears. I noticed that the shift rod head was about an inch longer than the one on my car. In fact, it looked as if it was extended somehow. It's odd. I noticed this because I had to put the bushing on the ball and snap it down, before inserting it into the shift rod head. If I didn't do that, the shift rod head was so deep that I couldn't push it on. I am hoping that I get lucky with this. Also, the cone set screw was replaced with a longer set screw, with a square head, that is drilled so it can be wired for additional safety. Anyway, more to come soon. I have my work cut out for me. |
SLITS |
Mar 30 2008, 08:11 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Joe, the center piston is what HAS TO BE FREE. It is the metering piston for the CIS. If stuck in the up position (pushed into the body of the fuel distibutor) you have WOT fuel flow, which is why you filled the exhaust will gas.
Cleaning that unit, the warm up regulator and injectors was what the post on NARP was all about. Tedious, but it can be done. There is a nut on the side of the fuel distributor that holds in a shim, spring and piston ... it is the main pressure regulator. If you take it out, don't loose ANYTHING. Clamp the exposed tit of the center plunger in a vise and pull to see if you can get it out of the housing. Clamp only on the tit as it is a machined piece matched to the bore of the fuel distributor. I will be at the shop today (Sunday) if you feel like driving to Riverside. I can give you a Fuel Distributor I have already cleaned up (bring your old one). In lieu of that ... couple of cans of Brake/Carb cleaner. Once you have pulled the center piston ... fill the cavity with brake cleaner and let it sit. Clean the piston carefully (don't scratch it) and set it aside. Flip the fuel distributor over and carefully fill each of the outlets with brake cleaner and let sit. Using a blow gun (rubber tipped is nice), start blowing back from the outlets on the top of the FD - don't use full pressure - trigger the gun slowly. When the passage is clear, you will feel air coming from the center cavity. Once all six are cleaned and clear, coat the piston with 3 in One oil and put it back in. Make sure it slides freely (the oil will give some resistance). Pull the injectors with the tool I described ... straight claw framing hammer and wood block. Using the brake cleaner can with the red plastic tube, insert tube into inlet of injector and trigger ... it has enough pressure to overcome the spring inside. You will see the spray from the injector change from dribbles to a fine conical spray when clean. The warm up regulator has a fuel in and a fuel out. Fill each hole with brake cleaner and let it sit for a while. Apply gentle air pressure with the gun until air flows freely through the holes (even in reverse). Once it's clean, you're ready to give the start a try. Warm up regulator modifys system fuel pressure according to temperature of the heating coil inside the unit and, depending upon the year, by vacuum also. Oh, the car will run without the Fuel Accumulator, but will not hot start. It smooths out pulses from the fuel pump and maintains pressure in the system for about 20 minutes after shutdown. I bought one from a member for $75 and one off eBay for $65. PS Gint ... I started to write this up for your site, but I HATE your template and gave up for the moment. Fixing The Dead |
Lo-Fi Version | Time is now: 26th September 2024 - 05:19 PM |
