> v8 t-stat, what else should i check
smrz914
post Dec 25 2003, 06:55 PM
Soon to be brightening the life of the person behind you.
So i took my t-stat out and put 3 1/8" holes in it. Anything i can/should chech while i'm in there?
John2kx
post Dec 25 2003, 08:51 PM
Paul,
I saw your similar post over on porchev. It's clear here your fighting a cooling issue. What is your temperature at highway speed? How high does it get (max.)?
What happens at extended idle?
Are you using a expansion tank? Where is it mounted? Does the coolant in expansion tank always come back to same level after car is completely cooled off (over night)? If not, you've got some sort of leak (internal or external) that could lead to high operating temp.
RH recommends a 16lb. radiator cap.
Do you know how to burp system?
Who's water pump are you using? Since you didn't have bleed holes in your thermostat, there is a chance you damaged impeller if rpm exceeded 2-3000 before t/s opened.
Have you checked all hoses to ensure no kinks exist in system?
I saw pics of radiator on your website. Do you have any others of engine bay and or hose routing?
John
smrz914   v8 t-stat   Dec 25 2003, 06:55 PM
Brad Roberts   Use a good Fel-Pro gasket (blue one that can be re...   Dec 25 2003, 06:59 PM
smrz914
  Dec 25 2003, 07:16 PM
boxstr   Paul Have you tried the thermostat that John Thoma...   Dec 25 2003, 08:41 PM
John2kx   Paul, I saw your similar post over on porchev. I...   Dec 25 2003, 08:51 PM
smrz914
  Dec 25 2003, 09:45 PM
boxstr   Correct you are. CCLIN914-8   Dec 25 2003, 09:59 PM
smrz914
  Dec 25 2003, 10:09 PM
rick 918-S   When to temp gauge gets up to 260 does the cap rel...   Dec 25 2003, 10:41 PM
Mueller   blown head gasket??? Paul, I have a snap-on rad/c...   Dec 25 2003, 10:55 PM
John2kx   (QUOTE) My gauge shows above 260 and this is taken...   Dec 25 2003, 10:59 PM
John2kx   Sorry for the mess guys........this was my first a...   Dec 25 2003, 11:05 PM
rick 918-S   You can go back and edit out what you don't wa...   Dec 25 2003, 11:07 PM
boxstr   John You got your point across. Good job. CCLIN914...   Dec 25 2003, 11:24 PM
smrz914
  Dec 25 2003, 11:53 PM
smrz914
  Dec 25 2003, 11:56 PM
John2kx   Paul, It appears you have not been using the righ...   Dec 26 2003, 12:07 AM
John2kx   adf   Dec 26 2003, 12:07 AM
John2kx   I doubt your water pump impeller is slipping on sh...   Dec 26 2003, 12:09 AM
John2kx   let's try that again   Dec 26 2003, 12:10 AM
smrz914   It's never been that high untill recently. I...   Dec 26 2003, 12:29 AM
smrz914   Did i use to many quotes? quotes are not coming up...   Dec 26 2003, 12:31 AM
steve@ottosvenice.com   One way to make sure all the air is out of the sys...   Dec 26 2003, 12:35 AM
smrz914   ok i'm moving the expantion tank and getting s...   Dec 26 2003, 12:36 AM
John2kx   Paul, Since your car ran fine until recently, I w...   Dec 26 2003, 03:39 AM
smrz914   John i've had 3 radiator caps in the car all a...   Dec 26 2003, 04:59 PM
Brad Roberts   Keep us up to date Paul. I was away from the compu...   Dec 27 2003, 11:16 PM
smrz914   So I put the car back together and bled it without...   Dec 28 2003, 07:34 PM
Brad Roberts   Yes. Get the pressure checker from Mueller. Do you...   Dec 28 2003, 07:42 PM
smrz914   Mueller i'm sending an e-mail... Brad I have ...   Dec 28 2003, 07:54 PM
Brad Roberts   John pointed out that you need to get *some* heat ...   Dec 28 2003, 07:56 PM
John2kx   Paul, I take it you test drove the car and still ...   Dec 28 2003, 08:11 PM
Brad Roberts   Hum.. he is measuring the water temp at its hottes...   Dec 28 2003, 08:17 PM
smrz914
  Dec 28 2003, 08:19 PM
smrz914
  Dec 28 2003, 08:55 PM
smrz914   I have to move the temp gauge pickup to the tip of...   Dec 28 2003, 09:07 PM
John2kx   Brad............I understood that his temp. probe ...   Dec 28 2003, 11:10 PM
smrz914   I use to use a combination of bleeding from the pe...   Dec 28 2003, 11:57 PM
Brad Roberts   Depending on what fans you have mounted.. they can...   Dec 29 2003, 12:01 AM
smrz914   It get's hot standing still as well. Doesn...   Dec 29 2003, 12:07 AM
John2kx   Paul, As a reference, my fans turn on at 179.6F a...   Dec 29 2003, 03:15 AM
smrz914   Oh it doesn't matter when the fans turn on it ...   Dec 29 2003, 03:12 PM
smrz914   I checked the spark plugs and they look really goo...   Dec 30 2003, 08:49 PM
John2kx   Time to try another gage.   Dec 31 2003, 02:18 AM
smrz914   what is the guage going to do? The car is boiling ...   Dec 31 2003, 02:24 AM
Brad Roberts   Paul, where are you located ?? I need to deliver ...   Dec 31 2003, 04:25 AM
John2kx   Paul, I didn't know you were boiling over.......   Dec 31 2003, 10:34 AM
smrz914   brad- I'm in lafayette, east bay, close to wal...   Jan 1 2004, 07:18 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 12:30 AM
