EMPI carbs, was this a mistake ? |
scotty b |
Mar 20 2008, 06:24 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Bought a set of EMPI carbs for a customers car. WHY Empis? Because after 2 weeks of unreturned calls to Weber direct we got fed up and called an Alfa supplier and he recommended the EMPIS. According to him they are as good as the Weber and is the same design. MY issue so far is the manifolds fit like SH*T I spent 30 minutes going from the car to the drill press reaming out ALL 4 holes to get the F-ers to fit.2 center holes had to be drilled out to 3/8" and the outer slots had to be drilled out to 3/8 AND lengthend. Was this a vision into the future (tommorrow) of how things will go when I start the car up ?
Once the manifolds were done everything else went fine. Is this a common issue and will the carbs end up being problematic? |
scotty b |
Mar 28 2008, 09:18 PM
Final verdict....
I'd buy em (IMG:style_emoticons/default/smile.gif) Got the carbs synched this morning, typical hex bar linkage issues with slight slop. Synched without linkage hooked up, then RE-synched with linkage hooked up. Test drive concluded the engine does indeed have quite a bit more power than a stock 2.0 ( shitty 2056 build ), carbs were smooth throughout, rod knock was almost inaudible on acceleration so the owner may feel like he has a decent car ....for a while (IMG:style_emoticons/default/av-943.gif) My only real complaint goes back to the fitment of the manifolds. Get to work on it EMPI !! Oh and send me my free set for pimping your carbs (IMG:style_emoticons/default/shades.gif) |
lonnie152 |
Apr 7 2008, 10:57 AM
Newbie Group: Members Posts: 40 Joined: 24-November 07 From: end of the oregon trail Member No.: 8,372 |
[quote name='scotty b' date='Mar 28 2008, 08:18 PM' post='1014115']
Final verdict.... I'd buy em i am getting ready to do this, what size did you get 40 or 44? thanks. ps. any installation recommendations? many thanks |
Lo-Fi Version | Time is now: 28th September 2024 - 02:42 PM |
