scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Bought a set of EMPI carbs for a customers car. WHY Empis? Because after 2 weeks of unreturned calls to Weber direct we got fed up and called an Alfa supplier and he recommended the EMPIS. According to him they are as good as the Weber and is the same design. MY issue so far is the manifolds fit like SH*T I spent 30 minutes going from the car to the drill press reaming out ALL 4 holes to get the F-ers to fit.2 center holes had to be drilled out to 3/8" and the outer slots had to be drilled out to 3/8 AND lengthend. Was this a vision into the future (tommorrow) of how things will go when I start the car up ?
Once the manifolds were done everything else went fine. Is this a common issue and will the carbs end up being problematic? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
yep, sync twice. on the second go round leave one of the idle speed adj screws off the stop you don't encounter any linkage bind. when everything is good, run the i.s.a.c back in til it just contacts the stop and doesn't increase the idle speed. all adj at this point are in teeny tiny increments with little pauses inbetween to allow the carbs to settle in.
k |
lonnie152 |
Newbie ![]() Group: Members Posts: 40 Joined: 24-November 07 From: end of the oregon trail Member No.: 8,372 ![]() |
two more questions:
1. do i have to replace fuel pump and if so to what? 2. do i have to replace distributor and if so to what ? again, many thanks. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:22 AM |
