scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Bought a set of EMPI carbs for a customers car. WHY Empis? Because after 2 weeks of unreturned calls to Weber direct we got fed up and called an Alfa supplier and he recommended the EMPIS. According to him they are as good as the Weber and is the same design. MY issue so far is the manifolds fit like SH*T I spent 30 minutes going from the car to the drill press reaming out ALL 4 holes to get the F-ers to fit.2 center holes had to be drilled out to 3/8" and the outer slots had to be drilled out to 3/8 AND lengthend. Was this a vision into the future (tommorrow) of how things will go when I start the car up ?
Once the manifolds were done everything else went fine. Is this a common issue and will the carbs end up being problematic? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
if you are running an F.I. pump, YES, replace it. check with jake raby and the type 4 store for a good replacement. look in the classic thread forum for andy's thread regarding powering the pump. if you can afford it, get the linkage from dave ellison @ triad. www.triadwestperformance.com is the correct email addy, i think.
actually, what i would do...source a set of weber 40 or 44s in the classifieds (there are some being offered), send them to Air Cooled Engineering in Salt Lake City for a rebuild, 1-801-943-1234. buy a new set of head stud correct cb tall manifolds. buy a triad. for about the same cost i've seen some of the empi packages go for you'll have a no bs carb package. or...buy the empi set and jump the hurdles mark has discribed in this thread. k |
Lo-Fi Version | Time is now: 28th June 2024 - 03:29 PM |
