Monday, 7 April 2025
> Testing D-Jet FI, Got a few questions
Spoke
post Apr 6 2008, 11:25 PM
Jerry
I'm prepping a 1.8L engine for the red 914 to replace the leaky 1.7L with one cylinder low on compression that's in the car. The installed engine has dual IDF40 Webers on it now.
When the PO bought the car, it had FI and was not running or was not running good. He took it to a local 356 shop and they pulled the FI and put on a single Weber just to get the car running.
When the 356 shop moved locations, I received a box full of FI stuff from the car. My goal is to test each component and get the FI running again. I've tested most of the components including the distributor contact points, temp senders, throttle switch, and MPS.
For the MPS, I just tested for vacuum leakage. It was leaking pretty badly so I took it apart and sealed it. I'll test it when I test the FI brain.
I got a few questions that I'll get to in a few posts. First question is will it damage injectors if they are operated w/o fuel pressure? I plan to run the brain with injectors dry.
Here's all the stuff I received:
Spoke
post Apr 8 2008, 03:27 PM
Jerry
Now to test the throttle contacts.
I did the open slowly and listen for 20 burps from the injectors. This looks ok.
Now to test the throttle-closed switch.
Set the engine speed to 2000 rpm, engine warm, MPS under vacuum. Following shot is with the throttle open. Normal injector pulse as expected. Note the nice square injector wave now that the injector is replaced by a resistor.
Close the throttle at 2000 rpm and the injector pulse decreases to a spike as expected. When injectors are connected during this test, there are no audible sounds from the injectors thus they are not opening at all with this little spike.
- Lo-Fi Version Time is now: 7th April 2025 - 12:23 AM
