ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
I am getting ready to drop my engine/transmission this weekend (1974 2.0L w/original FI - all stock).
How much does the engine + tansmission weigh? Harbor Freight has a transmission jack for $60.00 bucks. Will this work OK for me? 450 LB. CAPACITY TRANSMISSION JACK ![]() Perfect for removing transmissions on smaller vehicles. Heavy duty steel construction with ball bearing easy-roll casters. Includes 2''W x 43''L nylon strap to secure the load. Works with any 1/2'' drive ratchet handle (not included). Saddle tilts for easy positioning Maximum capacity: 450 lbs. Lift range: 7-1/4'' to 23-1/4'' Cradle size: 6-7/8'' x 13'' 3'' non-marring swivel casters Overall dimensions: 16-1/2''L x 15-5/8''W x 8''H Tool weight: 33.25 lbs. |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
You need to use a rachet to raise or lower that jack, better havea lot of extensions. I sure as hell wouldn't want to be under the engine when it is all free from the mounts - jack or not.
Lo-Fi Version | Time is now: 25th June 2024 - 10:08 PM |
