painting my intake......here is what i found |
jsayre914 |
Apr 10 2008, 11:52 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
So I pulled off the airbox on my 73 2.0. I then removed a few vacume lines which were loose anyway. (i am replacing them too) Then I removed the retaining nuts for my fuel injectors. the first injector was yellow, the other three are blue at the top. OH NO. next I pulled out the injectors, one was held in with a ziptie (IMG:style_emoticons/default/biggrin.gif) and another had no large seal at all. and the final one had 2 small seals...Now it gets better.....I noticed one of the three nuts holding the intake pipes was loose it came right off. then I noticed the other two were also loose??? Im not sure if the PO forgot to tighten or what. There was nothing holding this down at all. Once removed I saw lots of black exaust leak everywhere and even gasoline lying on the engine tin underneath. WOW, to think the car was running pretty good befor I started. Cant wait to see how she runs when Im done. (IMG:style_emoticons/default/driving-girl.gif)
SLITS |
Apr 10 2008, 12:36 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Yellow injector is a 1.7
Blue injectors are 1.8 and should have an almost square electrical attachment. '73 2.0 should have had green injectors Bosch 0 280 150 019 (Yeh, there's numbers cast into the tops on one side of the injector) Replace all your fuel hoses on the engine (7mm hose) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:15 PM |
