jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
So I pulled off the airbox on my 73 2.0. I then removed a few vacume lines which were loose anyway. (i am replacing them too) Then I removed the retaining nuts for my fuel injectors. the first injector was yellow, the other three are blue at the top. OH NO. next I pulled out the injectors, one was held in with a ziptie (IMG:style_emoticons/default/biggrin.gif) and another had no large seal at all. and the final one had 2 small seals...Now it gets better.....I noticed one of the three nuts holding the intake pipes was loose it came right off. then I noticed the other two were also loose??? Im not sure if the PO forgot to tighten or what. There was nothing holding this down at all. Once removed I saw lots of black exaust leak everywhere and even gasoline lying on the engine tin underneath. WOW, to think the car was running pretty good befor I started. Cant wait to see how she runs when Im done. (IMG:style_emoticons/default/driving-girl.gif)
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
In reality, the flow rates (in cc/min are different) with the lowest being the yellow, next up is the blue and lastly, the green is the highest.
You can dick around with fuel pressure to keep from running lean meaning increase beyond "normal" called for, but injectors will prolly start to leak at about 35+ psi. Hate to say it, but best course of action would be to obtain correct ones for the engine at your first opportunity (opportunity = money). Used ones can sell from $10 up each. Having them "rebuilt" (cleaned and calibration check) runs from $20 each and up to about $35 each. Edit: New ones are not cheap if you can even find them. There are some replacements on the market but I've never tried them. They are less expensive. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:24 PM |
