degreeoff |
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region ![]() |
OK I have a slightly smaller than setrab type oil cooler up front, 12an lines and the stock tank with a mocal t-stat...I have put 12 qts in this beast and still get no reading on my dipstick while @ idle....do I need more oil??
Thanks Josh |
degreeoff |
Well there is one that vents from the crankcase to the tank, then the one that vents from the filler neck....which runs into the above setup. It is the way the PO had the tank set up only without the catch tank just that filter off the filler neck. The catchtank and filter + hose wieghs about 1-2 lbs MAX
Lo-Fi Version | Time is now: 26th June 2024 - 09:23 AM |
