> Hey Jake what do you have for us on the MPG engine
LarryR
post Apr 9 2008, 11:14 PM
I would really like to know what you have for 914 in the way of a hi mpg, respectable performance package.
I figure the 914 should be able to kick out 40+ mpg and get a 0 - 60 time in under 7 seconds.
The new tdi jetta coming available in July will go 0 - 60 in 6.9 seconds and get 41 mpg in the city and 53 on the highway. However id does weigh 3300 pounds. I figure the 914 should be able to smoke that with the 1300 pound weight advantage.
I am really looking forward to seeing what you have come up with Jake.
trying not to hi jack the emissions thread but keep it on 914 world (IMG:style_emoticons/default/beerchug.gif)
BTW you said you need 10 or 12 additional people. I would be # 2 ... I would gladly buy a super efficient 914 engine as opposed to buying a tdi jetta. (IMG:style_emoticons/default/beer.gif)
toon1
post Apr 14 2008, 02:31 PM
QUOTE(messix @ Apr 14 2008, 12:38 PM) *
QUOTE(toon1 @ Apr 14 2008, 11:45 AM) *
Would there be any benifits to putting a 78mm stroke setup (crank, rods,pistons w/ the right pin height) on a stock 1.7?
Will the 9550 cam support a 78mm stroke 1.7? (IMG:style_emoticons/default/idea.gif)
here's the combo I am thinking of:
90mm pistons
78mm stroke
10:1 compresstion w/ flat top pistons
.040 D/H
stock 1.7 heads
piston dwell at tdc and bdc would effectively be longer, the smaller bore would give less dead space at piston crown to ringland, should be less likely to detonate, but small bore would shroud valves and restrict port flow.
trust jake, i'm shure he could come up with a combo that could push 40-45 mpg @ 120hp but would you pay $20k for all the coatings and one off stuff to make it happen?
This combo is close to the super 2L. The purpose of having the small bore and long stroke w/ small valves is to increase port velocity. with the right cam, it's possible to continue an intake air charge even AFTER the piston is on it's way back up. This creates great mixture properties.
NO, I would not/ could not(sam I am (IMG:style_emoticons/default/biggrin.gif) ), pay 20k for all the coatings to get 40-45MPG.
What if this combo could consistantly yield 32-35 with the possibility of 40!?
I have a two cyl. engine right now that is this excact combo
90mm bore
78mm stroke
8.2:1 comp.
3600rpm redline
it swings a 13" surface drive prop. and pushes a boat around through the mud and weeds. I lives it's life to to create huge amounts of low end torque @ low rpm's ( and does a good job of it).
If it had 2 more cyl's. (ala a T4) it would be a great motor (IMG:style_emoticons/default/idea.gif)
LarryR   Hey Jake what do you have for us on the MPG engine   Apr 9 2008, 11:14 PM
ericread   As I said in the earlier thread, I am #1 in line.....   Apr 10 2008, 01:29 AM
johannes   The high mpg engine is already in the pricelist. ...   Apr 10 2008, 07:18 AM
Travis Neff   The high mpg engine is already in the pricelist....   Apr 10 2008, 07:37 PM
Vacca Rabite   I love the torque curve. Its like a little diesel...   Apr 10 2008, 08:30 AM
brer   my 40hp bettle has gotten 45mpg :)   Apr 10 2008, 11:06 AM
Rusty   Jake's in the business to sell engines. That ...   Apr 10 2008, 11:17 AM
Jake Raby   The Super 2 Liter isn't cost effective to buil...   Apr 10 2008, 11:22 AM
messix   The Super 2 Liter isn't cost effective to bui...   Apr 10 2008, 11:31 AM
Travis Neff   :popcorn: :D   Apr 10 2008, 11:37 AM
Jake Raby   Yes, L Jet compatible versions would hit the ceili...   Apr 10 2008, 11:39 AM
LarryR   Yes, L Jet compatible versions would hit the ceil...   Apr 10 2008, 11:49 AM
messix   Yes, L Jet compatible versions would hit the ceil...   Apr 10 2008, 12:20 PM
McMark   That sounds like a REALLY nice combo!   Apr 10 2008, 11:45 AM
ericread   Jake; I have a 2.0L original engine now. How muc...   Apr 10 2008, 11:49 AM
McMark   Eric, buy a 1.7 core motor. ;)   Apr 10 2008, 12:12 PM
ericread   Eric, buy a 1.7 core motor. ;) Bummer :(   Apr 10 2008, 12:20 PM
Pnambic   Eric, I imagine you wouldn't have too much tr...   Apr 10 2008, 12:44 PM
ericread   Eric, I imagine you wouldn't have too much t...   Apr 10 2008, 01:10 PM
horizontally-opposed   Hey Jake, don't you owe me a call? :shades2: ...   Apr 10 2008, 01:03 PM
Jake Raby   Pete, Yeah.. I'll ring you this evening.. Kee...   Apr 10 2008, 02:40 PM
LarryR   Pete, Yeah.. I'll ring you this evening.. Ke...   Apr 10 2008, 04:17 PM
RJMII   Ok I could not resist I went ahead and did the m...   Apr 10 2008, 05:49 PM
RJMII   There are constraints we must work around on this...   Apr 10 2008, 05:44 PM
r_towle   Pete, Yeah.. I'll ring you this evening.. Ke...   Apr 10 2008, 07:32 PM
r_towle   50 MPG minimum...you can do it... Rich   Apr 10 2008, 03:09 PM
Jake Raby   50 MPG minimum...you can do it... Rich Yes, an...   Apr 10 2008, 04:47 PM
toon1   Jake, is it possible to start a thread on tuning f...   Apr 10 2008, 05:04 PM
r_towle   Base the difference on what you would spend with ...   Apr 10 2008, 06:08 PM
Travis Neff   The super 2 Liter does not come in a kit   Apr 10 2008, 06:09 PM
r_towle   Well, I went over to Jakes forum...I looked around...   Apr 10 2008, 06:46 PM
Travis Neff   Check post #3 for the urls to the forum topic and ...   Apr 10 2008, 06:51 PM
Root_Werks   Jake, I like the idea of the 1911cc engine. I ha...   Apr 10 2008, 07:45 PM
r_towle   nope, I am waiting for Jake to reply to this. He w...   Apr 10 2008, 07:45 PM
Jake Raby   The thread on super MPG was on my forum when it wa...   Apr 10 2008, 09:21 PM
RJMII   The thread on super MPG was on my forum when it w...   Apr 10 2008, 11:34 PM
jd74914   Hmm. I'm really interested to see where this g...   Apr 10 2008, 09:25 PM
LarryR   One kind of interesting note is that the right com...   Apr 10 2008, 09:30 PM
messix   low end torque and gearing make a quick car get go...   Apr 10 2008, 09:58 PM
biosurfer1   Larry, That is why I drive an old, worn, 1.7 that...   Apr 10 2008, 10:36 PM
Eric_Shea   Hmmmmmmmmm 76 912E, Super 2... Hmmmmmmmmmmmm   Apr 10 2008, 11:07 PM
r_towle   funny, I was thinking hmmmm 65 356 sc coupe....50m...   Apr 10 2008, 11:16 PM
LarryR   Larry, That is why I drive an old, worn, 1.7 tha...   Apr 11 2008, 12:25 AM
johannes   FYI... Theese figures come from a french magazine...   Apr 11 2008, 02:06 AM
Jake Raby   ABSOLUTELY!!! Combustion effectivene...   Apr 11 2008, 10:53 AM
Todd Enlund   Anybody know how well a Type IV will fit in a Type...   Apr 11 2008, 04:45 PM
Bleyseng   seen two and it fits...finding 411 HE's is har...   Apr 12 2008, 10:25 AM
r_towle   I would think, based upon all the stuff out there ...   Apr 12 2008, 11:00 AM
Todd Enlund   seen two and it fits...finding 411 HE's is ha...   Apr 12 2008, 12:20 PM
Dave_Darling   I'd love to see BSFC graphs from Jake's dy...   Apr 12 2008, 03:43 PM
Jake Raby   Building the engine square costs just as much as m...   Apr 12 2008, 07:58 PM
RJMII   My recommendation of a 1911cc combination remai...   Apr 12 2008, 09:30 PM
Jake Raby   Sure, what do you have now??   Apr 14 2008, 10:41 AM
RJMII   Sure, what do you have now?? I have: no idea w...   Apr 14 2008, 10:58 AM
Jake Raby   So, did you buy this engine or build it?? Partiall...   Apr 14 2008, 12:00 PM
RJMII   So, did you buy this engine or build it?? Partial...   Apr 14 2008, 01:58 PM
Dave_Darling   ...What compression ratio should I am for? Or does...   Apr 14 2008, 09:09 PM
RJMII   ...What compression ratio should I am for? Or doe...   Apr 14 2008, 10:27 PM
toon1   Would there be any benifits to putting a 78mm stro...   Apr 14 2008, 12:45 PM
messix   Would there be any benifits to putting a 78mm str...   Apr 14 2008, 01:38 PM
toon1   Would there be any benifits to putting a 78mm st...   Apr 14 2008, 02:31 PM
HAM Inc   78 x 90mm is a great combo. The valves are only sh...   Apr 14 2008, 04:40 PM
toon1   78 x 90mm is a great combo. The valves are only s...   Apr 14 2008, 07:12 PM
Todd Enlund   78 x 90mm is a great combo. The valves are only ...   Apr 14 2008, 07:53 PM
ChrisNPDrider   No doubt twin plug is our best bet for best perfor...   Apr 15 2008, 01:10 AM
Jake Raby   Keep this realistic!!!! Quit the d...   Apr 15 2008, 01:21 AM
johannes   Jake , as your engine runs cooler , what about rem...   Apr 15 2008, 03:01 AM
Jake Raby   Battery voltage increase ignition system voltage. ...   Apr 15 2008, 10:59 AM
RJMII   Ok, so I got an email back. I've got a scat ca...   Apr 15 2008, 12:03 PM
Todd Enlund   Differences between 1.7 heads and 1.8? http://w...   Apr 15 2008, 12:25 PM
RJMII   Differences between 1.7 heads and 1.8? http://...   Apr 15 2008, 12:50 PM
r_towle   look at the top of any page here, there is a butto...   Apr 15 2008, 01:03 PM
RJMII   OOPS. I really didn't mean to ask that. At the...   Apr 15 2008, 06:40 PM
Mark Henry   If you want great MPG the engine is only part of i...   Apr 15 2008, 06:56 PM
Todd Enlund   To me this sounds like in a 914 it would get pret...   Apr 15 2008, 07:36 PM
pete-stevers   great read! of course there is a tdi option as...   Mar 1 2010, 12:40 PM
johannes   That' what i call digging out an old thread.....   Mar 1 2010, 01:49 PM
- Lo-Fi Version Time is now: 6th January 2025 - 04:35 PM
