Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
After replacing all 4 flexible brake lines I was unable to successfully bleed the system. Brakes worked fine before I started. Replaced the master cylinder (turned out it was needed by looking at it). Bled the system and got a good pedal. Left the car for a while. Came back to find pedal nearly to the floor. There is no evidence of any leakage. Any ideas out there?
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I bet it has somthing to do with the proportioning (sp?) valve. On other cars I have run into this problem before, once even going through a 4 liter jug of fluid! I finally gave up and cracked the lines as I blead. Guess what? IT WORKED. I don't recommend this method (IMG:style_emoticons/default/wink.gif) but 'what the hey'! It was messy though. (IMG:style_emoticons/default/sad.gif)
Lo-Fi Version | Time is now: 21st June 2024 - 12:01 AM |
