Smitty911 |
Member ![]() ![]() Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California ![]() |
I purchased a 1974 2.0 non runner. The shop said FI issues. I've been reading the forum and found Daves site with trouble shooting the FI system. Alot of the checks are done at the connector end of the ECU connector.
1. Problem the ECU is a remanufactured unit and the cable is connected INSIDE the ECU. 2. What are the Values for just the individual parts? So far the Battery read 0.00 Volts, it's on the charger now. It started taking about 6 amps though, might be salvagable. All the Ignition wires are miles to long and cracked. The boots blocking the tin are melted and hard as rocks. Wire routing is non-existantant. They are all over the place running in and around, under or though everything. Fuel lines look to have been replaced not long ago. Ideas??? Thanks Smitty |
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
I think I would check the simple/obvious items before digging into the ECU based on what some shop said.
New: Cap Rotor Plug wires Plugs Points Fresh Gas Now, does it have spark? Can you hear the fuel pump kick on when you turn the key on? Are you getting fuel? Check your grounds, especially where the injectors ground to the block and the body to transmission strap. And of course.... (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 28th June 2024 - 08:12 PM |
