Smitty911 |
Member ![]() ![]() Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California ![]() |
I purchased a 1974 2.0 non runner. The shop said FI issues. I've been reading the forum and found Daves site with trouble shooting the FI system. Alot of the checks are done at the connector end of the ECU connector.
1. Problem the ECU is a remanufactured unit and the cable is connected INSIDE the ECU. 2. What are the Values for just the individual parts? So far the Battery read 0.00 Volts, it's on the charger now. It started taking about 6 amps though, might be salvagable. All the Ignition wires are miles to long and cracked. The boots blocking the tin are melted and hard as rocks. Wire routing is non-existantant. They are all over the place running in and around, under or though everything. Fuel lines look to have been replaced not long ago. Ideas??? Thanks Smitty |
john grier |
Member ![]() ![]() Group: Members Posts: 303 Joined: 27-June 04 From: Hermitage, Tn Member No.: 2,265 Region Association: South East States ![]() |
This can't be stressed to much.
Check the basics first. Ask me how I know? Ok here goes. Last year while driveing down the road, hit a small bump. Car promply died. Had it towed home. Spent two days swaping dizzy and other parts. Finially checked the condenser. The wire broke. Cheap fix would saved alot of time. John |
Lo-Fi Version | Time is now: 28th June 2024 - 08:44 PM |
