FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Hello 914 World Members!
I am starting on restoring a $500 914 that was left in a field for several years with no windshield. The car belonged to the POs older brother and thus has sentimental value. The sold it to me on the condition that I not part it out. I was looking for a project so this was fine with me. This is my first restoration project so I figured I would learn a lot (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) The car is a mixture of really good sections, appears to have suffered no major accidents, is straight, never been repainted--but it has totally rusted out floors and hell hole. All the suspension mounting points are not rusted. The door gaps are all even and good. If I can replace the floors, I think it will be a good straight car. Many small parts were stolen while it was "stored" and the wiring loom is a complete loss. Thanks for any comments...John |
FourBlades |
Cut out the front trunk. About now you start wondering if this is such a good
idea and if you really know what the hell you are doing. (IMG:style_emoticons/default/blink.gif) ![]() Cut the center out of the old piece (left side of picture) so it will lay flat on top of the new trunk section and then carefully draw around it. The cutting wheel cuts a kerf about two of them teeny ruler marks wide so draw the cut line a little wide around the edge of the old piece. It is easier to cut more later than to fill in a big gap with the welder. ![]() The new piece actually fits pretty well. A little trimming here and there and it is good to go. I have learned not to try to perfect the fit of a patch. Otherwise you start out with big patch that is pretty close and you keep trimming it and trimming it and it is always too short no matter how much you cut off. (IMG:style_emoticons/default/huh.gif) ![]() Cleaned the edges to bare metal on both sides. Tack welded the corners, then the middles, then in between. Then the cycle repeats itself until the tacks are an inch or so apart. It is easier to hammer a patch to fit once it is partly tacked on. Once part of a patch is held rigidly by welding the other parts bend easily with the hammer. ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 07:54 AM |
