Anyone ever break a head stud?, Looking for ideas, tools success stories, horror stories, what cha got |
rick 918-S |
Apr 27 2008, 04:56 PM
Hey nice rack! -Celette Group: Members Posts: 20,785 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm building a 928 hybrid engine which is comprised of a 5.0L 32 valve short block with 16 valve euro spec "S" heads, spyder and CIS from the 4.7L "S" engine.
I stole some time from my busy work schedule to prep my 928 block for the machine shop. The head studs need to be removed for the boring process. Now I've pulled studs before without incedent. But as Murphy would have it, this time I broke one of the studs flush at the start of the threads. So I have the threaded section ( 1 1/4"long ) hardened head bolt stuck in the block. Normally this wouldn't be a problem, but the stud is free standing in a 3 1/2" deep hole in the block! Here's a crude drawing of the problem I'm faced with. Here's the stud. Here's the stark reality of the stud in and out of the block. The stud slides down a 3 1/2" deep hole in the block before it starts to thread in. I'm going to make a drill collet as a guide for a pilot bit. The problem is I need a long, reverse twist drill bit. Most drill bits are approx 5" long. the hole is 3 1/2", the threaded section is 1 1/4" for a total of 4 3/4". See the problem? Then, what the #$!! do you drill a hardened bolt with? Anyone know of a good tool source? This is beyond most Mac and Snap on stuff I would think. |
Richard Casto |
Apr 28 2008, 08:14 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
I have no idea what the cost of this is, but EDM (Electrical Discharge Machining) aka Spark Erosion may be the right tool for the job.
Maybe you can find someone local to you like this guy (found via Google search)... http://www.brokentap.com/ |
Richard Casto |
Apr 28 2008, 08:21 AM
I have no idea what the cost of this is, but EDM (Electrical Discharge Machining) aka Spark Erosion may be the right tool for the job. Maybe you can find someone local to you like this guy (found via Google search)... http://www.brokentap.com/ Another Google search for EDM services, but this time for someone in MN... http://www.twincityedm.com/ Good luck on getting the stud removed! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 23rd November 2024 - 11:24 PM |
