smdubovsky |
Member ![]() ![]() Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region ![]() |
Hi guys, been a while since I've posted. Im reworking the cage in the /6 to fit me better. When I bought it, it had a "short people" main hoop design;) The harness bar went straight across and the triangulation went the the upper corner. It limited the seat from moving back another 8+". The harness bar was also *WAY* too low. I'm 6'2" w/ long legs and need all the room I can get.
Here is what it looks like now (red = the bars I cut out, green = ones Im going to install) ![]() Here you can sorta see how low the old bar was - below the door tops. ![]() Ok, now here is my big question: Instead of the usual zig back behind the driver (tight against firewall), zig forward across the center firewall 'hump' (tight to firewall), and head straight across to the passenger side (w/ a gap to the firewall) - I want to do a zig back (tight to firewall), go THROUGH the hump, tight against passenger side firewall, and zig forward to the main hoop. This will be just above the existing fan cutout the POs did, and above the top of the fan housing (but not really as much as the pic shows). When the seat tilts back a little more, the shoulder 'wing' gets pretty darn close to the hump so there really isn't space to route the bar completely inside the cabin. I can't really bolt eyebolts to the firewall and forego the harness bar either - they'd get too close to the seat w/ the mounting clips and adjusters (which would then actually be sitting on my shoulders.) Heres s shot of where I want to cut though the 'hump' to put the harness bar. ![]() I'd leave ~1/8" between the firewall and bar behind the seats so I could still wrap the harnesses around. Thoughts? Has anyone done this? I'm not racing this car so I have *NO* class rules to follow, but thoughts about legality if I ever get rich and change my mind would be interesting;) I think if I did a larger cover w/ ears and sealed it well, it wouldn't really count as another point. |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
I'm worried that the harness bar running through the hump will make an already difficult to replace alternator impossible to replace in the car. Have you considered using smaller diameter tubing for the harness bar? I don't know what the organization's rules say but I think that a slightly smaller bar with no bends in it will be stronger than a larger bar with bends. My old roll bar had a bolt in harness bar that mounts to the stock shoulder belt lugs. My cage has no harness bar at all, just 3" X 4" plates bolted to the firewall with the eyelets bolted through, nobody has questioned it.
Lo-Fi Version | Time is now: 27th June 2024 - 08:45 PM |
