Lavanaut |
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest ![]() |
Hey all,
I'm researching what it would take to convert my '74/4 rear axles to 911 parts as a potential approach to my rear 5-lug conversion. The piece of the puzzle that's got me confused right now is the joint flange, the piece which the transmission-side CV joints bolt up to. PET shows two part numbers for the '70 911:
1. Despite different part #s, my understanding is that at least one of the 1970 911 joint flanges *will* fit my 914...correct? 2. Which of the two 901 part numbers should I be on the lookout for, and what's the difference between the two? Shout-out to Eric Shea for schooling me on this stuff! (IMG:style_emoticons/default/aktion035.gif) (Eric, I figured I'd go ahead and research in case our parts swap doesn't pan out for some reason. Can't hurt to learn a little more... (IMG:style_emoticons/default/wink.gif)). Thanks, Reid |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
... you'll need the "coarse" spline transmission output shafts. i got mine from a '77 (i believe) 911 ... btw. the 911 CVs won't fit the 914 axle shaft (different spline) and the 911 axle shaft will be too short ... that's why i went with 944 CVs on my car. (IMG:style_emoticons/default/shades.gif) Andy |
Lavanaut |
you'll need the "coarse" spline transmission output shafts. i got mine from a '77 (i believe) 911 ... That makes sense I think ~ "course" meaning fewer, fatter splines, right? You don't remember the count do you? (IMG:style_emoticons/default/biggrin.gif) QUOTE btw. the 911 CVs won't fit the 914 axle shaft (different spline) and the 911 axle shaft will be too short ... that's why i went with 944 CVs on my car. Eric mentioned your setup to me, I've been meaning to read through the progress thread. He also mentioned the possibility of going with an aftermarket axle from Sway-A-Way, something I'm looking into as well. Reid |
Lo-Fi Version | Time is now: 26th June 2024 - 12:23 AM |
