dandh |
73-Project 914 ![]() Group: Members Posts: 33 Joined: 13-April 06 From: Las Vegas, NV Member No.: 5,857 Region Association: Southwest Region ![]() |
Got most of the stuff I'm going to need for the big brake change this wk end,rotors,seals,calipers pads,hoses,bearings, ? should I change out the m/c too ?
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Depends... are you using stock calipers up front?
A 19mm will give you a harder pedal but it will take more effort. You mention big and change in the same sentence. If you are going to a larger pistoned caliper up front then you should change to the 19mm E. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:11 AM |
