rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
This past weekend I installed a thru body H&H brand 19mm front sway bar in my 75 chassis I'm converting to a /6. I am running 911 Boge struts up front and Koni shocks in the rear with 140lb. springs. The sway bar has four adjustment holes, the instructions state to start with the softest ( farthest from pivot ). I installed it useing the 2nd hole from the end so the next firmness level. My car is still a long ways from being a driver but what can I expect with the bar at this setting? According to the install instructions the setting I have picked gives 742 lbs./in. of resistance/force. So you guys that know what you're doing explain to me when are you adjusting the bars and to what level do you go? I'm being told my combo should be a good street/AX setup. My bars on my 911 are not adjustable so this is new to me so talk to me like I'm a 10 year old (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 05:05 AM |
