r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I started this on another site...not alot of joiners.
The idea is to test, tune, and tweek your car, and your driving style, to get the most MPG in a 914. This is a redo of a contest that the NY region did with 356's back in the day. These guys got 70mpg with one guy getting 100mpg. Alot of it is tuning, more if it is driving style. Here are the ground rules. We have several classes. 1.7, 1.8, 2.0, 2.0/6, and modified (all the rest of you), and vendors (special class) This is for 914's Using the honor system the goal is to win the mpg goal in your class. I am in 1.7 and aiming for 40mpg this first round out.. The contest will run from Memorial Day till Labor Day...this gives us all time to change things and tune things. This is meant to be fun with the 914magazine offering t-shirts as the prize...so its not meant to be for cheating. So, if you want to join, list the following. year, motor, tire size Use GPS or highway mileage markers to verify your odometer so we are all being fair. Rich |
r_towle |
damn, 24mpg for that beast is pretty interesting.
What do you think you can get it up to??? I know you just got it running again, so you sure need time to tune and play. BTW (OT) I found an article in Up Fixen der Porsche regarding foam in the oil filler. The cure was to add air (open a port) in the head/valve cover. Apparently the issue is that there is no fresh air getting into the system so the oil foams up due to moisture. The moisture is cured by allowing air into the system....so, you have have these ports, and they may be blocked or closed...take a look. Rich |
Lo-Fi Version | Time is now: 24th June 2024 - 07:20 AM |
