rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
Is there a pictorial or diagram of all the empty cavities on a 914 that can/should be sprayed with rustproofing goop? As I make my way thru my 914 in regards to surface rust cleanup on exposed exterior surfaces I would like to also spray in all empty cavities some goop. So where are all of these cavities? I know the longs but where else? And where are the best places to drill/spray some goop?
shoguneagle |
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California ![]() |
Scotty, thanks for the input. I do use a rust converter such as 10-20% Phosphoric Acid (or metal etch or jasco, etc.) Let it set for 10 to 20 minutes, and wash out several time air blowing as much out as possible after each washing; then apply a solution of baking soda and water 10-30% to neutralize any remaining acid (may do this several times since I do not leave any potential powder residual); again wash wash several times with water and air blowing after each wash. I then let it dry for several days. It is after this procedure is where I want to use Perry's technique.
Steve Hurt |
Lo-Fi Version | Time is now: 28th April 2025 - 09:14 PM |
