Help me sort out my engine, My combo is not working and needs to be revised |
Phoenix914 |
May 19 2008, 10:01 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
I recently had my 914 emissions tested and it failed. Yes, in Delaware all cars newer than 1969 have to pass emissions. Anyway, this failure brought to my attention that the combination of engine specs and fuel injection are causing this problem. I had an enlightening conversation with Jake Raby about what I had and he basically said that the reason for the emissions problem is that the cam I have is too radical for D-jet. He said he was surprised it ran at all. It does, but has no guts after 4k RPM.
So here is what I have: The engine was rebuilt 20 years ago after some sort of catastrophic failure. It was originally a 2.0, and is now a 2056. The cam is listed on the paperwork as 272 degree. Jake said this is pretty radical for a 2056. The original owner told me he used to have dual carbs on the car, but decided to put the D-jet back on because of emissions. Ha! I was already planning to do some upgrades to the valve train because it is seriously noisy. The rocker arm springs must be getting shoved around too much by that cam. Solid rocker spacers and possibly 911 adjusters/1.7 rockers were on my to-do list anyway. So what I need to decide is which way to go with reconfiguring this combo. I could pull off the D-jet and throw some gnarly Webers on, or possibly an updated injection system. Or, I could crack open the case and replace the cam with something milder that will work with D-jet. This is just a daily driver type car. I want something that works, is fairly reliable, and won't require too much tinkering. At least, not any more than one would expect for a 35 year-old car. I also want to keep the budget for this operation at a minimum. What to do...? (IMG:style_emoticons/default/confused24.gif) |
TeenerTim |
May 19 2008, 12:18 PM
Senior Member Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
I'm not familiar with Delaware but my guess is that if they are checking emmisions out of the pipe they are also doing a visual equipment check. Switching to carbs would cause you to fail the visual regardless of how clean the exhaust is.
Lo-Fi Version | Time is now: 28th June 2024 - 06:17 PM |
