KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
My motor is a 1911 I got used. It has a carb cam of unknown spec. It runs pretty good. The valve adjusters are a swivel foot style adjuster and the top of the adjuster whacks the inside of the valve cover. This does two things. First, it eventually breaks a hole in the cover. Second, the tapping causes the valve cover to lift ever so slightly from the head, allowing the gasket to buckle a little and leak oil.
I assume I could swap out the adjusters with stock ones or I can cut the adjusters to make them a smidge shorter and re-tap them to make sure I can still use them. I was wondering if there is an option for a taller valve cover of some sort? I've seen screw on covers, but I am not sure how those work or if they provide any more clearance. Here is a picture of a busted valve cover from the last time this happened. ![]() TIA |
JB 914 |
Daddy! Finish my car NOW!!! ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 ![]() |
Joe i have a set of valve covers that are not stock and i'm not using them. you are welcome to them. PM me.
Lo-Fi Version | Time is now: 22nd June 2024 - 09:26 PM |
