Upper sping perch, How to remove? |
914helo |
May 22 2008, 09:00 AM
Member Group: Members Posts: 235 Joined: 29-September 04 From: Southern Utah Member No.: 2,859 Region Association: None |
I pulled out the shock/spring in the rear of my '73, and after compressing the spring, I can't get the top nut off to remove the spring perch. When I twist it while securing the shock, the inner actuator rod just spins with the top nut. I'm afraid to clamp down on the actuator rod while loosening the nut. More PB Blaster? (IMG:style_emoticons/default/confused24.gif)
davep |
May 22 2008, 09:12 AM
914 Historian Group: Benefactors Posts: 5,220 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
There should be flat sides to hold with a wrench; that is, two wrenches are required. Hold the rod with one, turn the nut with the other.
Lo-Fi Version | Time is now: 26th December 2024 - 07:48 PM |
