bjinright |
Newbie ![]() Group: Members Posts: 13 Joined: 9-June 06 From: Montgomery, ALABAMA Member No.: 6,192 ![]() |
I've opened this thread to see what everybody likes Rubber-wise. (well that came out wrong) (IMG:style_emoticons/default/confused24.gif)
Anyway for AUTO-X iv been using: Falken Azensis 615 205/50R15 in C stock on stock Fuchs(sp) But I'm looking to see what others have been succesfull with in: CS STS2 (up to 225mm but are the 215s working for anybody?) SP MOD I'm also wondering if you use tire size to "regear" your 914. |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
V710s 205/50R15s on 7x15 cookies Front 225/50R15s on 7x15 rears. Fronts fit perfectly under sock fenders. Rears are under puled flares and spacers to keep them from rubbing on the inner fender. I run no spacers up front, and 1" per side out back.
I used to run 205/50s R15s on 6.5" Minilites, required a 1/4 spacer out back. Those AVS's I use as street tires, yes they do suck, looking at replacing them with Nittos so I can run to the events and if it rains I have something that moves water. |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
V710s 205/50R15s on 7x15 cookies Front 225/50R15s on 7x15 rears. Fronts fit perfectly under sock fenders. Rears are under puled flares and spacers to keep them from rubbing on the inner fender. I run no spacers up front, and 1" per side out back. I used to run 205/50s R15s on 6.5" Minilites, required a 1/4 spacer out back. Those AVS's I use as street tires, yes they do suck, looking at replacing them with Nittos so I can run to the events and if it rains I have something that moves water. Why not run 225's in the front? I normally get understeer as it is. Do the cookie cutters require that you run a spacer in the rear? I have 15x8 fuchs in the rear now and they fit w/o any spacers...I guess the two rims have different back spacing. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 01:51 AM |
