Fuel pump relocation questions, and other problems |
championgt1 |
Jun 2 2008, 02:06 AM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
I finally got my car what I thought was running right. However after a half hour drive the car started to buck at around 3000 rpm. When I came to a stop the car just died. It would restart, but as soon as I gave it some gas it would just die. Acted like it was starved for fuel.
The TPS has been adjusted per the tech articale on pelican. The plugs look good, pump runs and is getting fuel to the cylinders. I thought it could be the fuel filter. This is where it gets strange. My car is a 74 which should have a small inlet and outlet. The filter is in its stock location but has a small inlet and a large outlet like the filters on a 75, 76. The filter on the right is the replacement, the filter on the left came out of the car. The fuel pump was relocated to the front at some point. Couple of questions. #1 Does anyone have pictures of a installation and did you leave the filter in the stock location? #2 Should the filter be between the tank and the pump,not after the pump? #3 The fuel filter that I removed was bulged outward. What could cause this? I'm sure I will come up with more questions. Just a little tired right now. |
jcd914 |
Jun 2 2008, 02:29 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Plastic fuel filter should never be on the pressure side of the pump, always on the suction side. Too much chance of the plastic failing from the pressure, they weren't designed to be under pressure. The bulging might be a sign yours is ready to fail. I has seen the plastic filters leak from the pressure of the fuel sitting in the tank. There is a nice BMW metal FI filter that has small in small out fitting for clamped fuel hose that could be used, not sure what else is out there but I am sure there are other.
I would suggest that if you have relocated the fuel pump up front then move the filter up front as well. If you don't has an access panel to get to the pump and filter up front them put a metal filter in the rear. Jim |
Lo-Fi Version | Time is now: 27th June 2024 - 11:50 PM |
