championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
I finally got my car what I thought was running right. However after a half hour drive the car started to buck at around 3000 rpm. When I came to a stop the car just died. It would restart, but as soon as I gave it some gas it would just die. Acted like it was starved for fuel.
The TPS has been adjusted per the tech articale on pelican. The plugs look good, pump runs and is getting fuel to the cylinders. I thought it could be the fuel filter. This is where it gets strange. My car is a 74 which should have a small inlet and outlet. The filter is in its stock location but has a small inlet and a large outlet like the filters on a 75, 76. The filter on the right is the replacement, the filter on the left came out of the car. ![]() The fuel pump was relocated to the front at some point. Couple of questions. #1 Does anyone have pictures of a installation and did you leave the filter in the stock location? #2 Should the filter be between the tank and the pump,not after the pump? #3 The fuel filter that I removed was bulged outward. What could cause this? I'm sure I will come up with more questions. Just a little tired right now. |
championgt1 |
The lines coming out of the tunnel are in good shape. Another question is why are there two lines coming out of the tunnel? There is a small line and a bigger line. Is one of them a return line and if so which one is it?
This picture is of the lines coming out of the tunnel. ![]() The big line had the filter on it. On the other side of the filter is a small line that goes into the engine compartment and feeds the #3 and 4 cylinders. The other line also goes into the engine compartment and feeds the #1 and 2 cylinders. I pulled the carpet back in the passenger foot well to see if there was a acsess panel but I got not get the foam block out. I would have to break this into pieces to get it out. Any ideas on this? |
Lo-Fi Version | Time is now: 28th June 2024 - 12:06 AM |
