championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
I finally got my car what I thought was running right. However after a half hour drive the car started to buck at around 3000 rpm. When I came to a stop the car just died. It would restart, but as soon as I gave it some gas it would just die. Acted like it was starved for fuel.
The TPS has been adjusted per the tech articale on pelican. The plugs look good, pump runs and is getting fuel to the cylinders. I thought it could be the fuel filter. This is where it gets strange. My car is a 74 which should have a small inlet and outlet. The filter is in its stock location but has a small inlet and a large outlet like the filters on a 75, 76. The filter on the right is the replacement, the filter on the left came out of the car. ![]() The fuel pump was relocated to the front at some point. Couple of questions. #1 Does anyone have pictures of a installation and did you leave the filter in the stock location? #2 Should the filter be between the tank and the pump,not after the pump? #3 The fuel filter that I removed was bulged outward. What could cause this? I'm sure I will come up with more questions. Just a little tired right now. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Large line was the supply from the fuel tank, gravity feed to the original pump. Small line is the return from the fuel pressure regulator, driver side of engine compartment.
The OE access panel for front pump is in the front trunk. I have seen relocation jobs were there is no access panel, where they mimicked the OE set up and where they strapped the pump and filter to the steering rack or cross beam. So if yours has been relocated, you're just going to have to look around. Under the passenger floor foam block would not be a good place since a fuel leak could put fuel in the passenger compartment. (IMG:style_emoticons/default/sad.gif) Good luck Jim |
Lo-Fi Version | Time is now: 28th June 2024 - 12:25 AM |
