Fuel pump relocation questions, and other problems |
championgt1 |
Jun 2 2008, 02:06 AM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
I finally got my car what I thought was running right. However after a half hour drive the car started to buck at around 3000 rpm. When I came to a stop the car just died. It would restart, but as soon as I gave it some gas it would just die. Acted like it was starved for fuel.
The TPS has been adjusted per the tech articale on pelican. The plugs look good, pump runs and is getting fuel to the cylinders. I thought it could be the fuel filter. This is where it gets strange. My car is a 74 which should have a small inlet and outlet. The filter is in its stock location but has a small inlet and a large outlet like the filters on a 75, 76. The filter on the right is the replacement, the filter on the left came out of the car. The fuel pump was relocated to the front at some point. Couple of questions. #1 Does anyone have pictures of a installation and did you leave the filter in the stock location? #2 Should the filter be between the tank and the pump,not after the pump? #3 The fuel filter that I removed was bulged outward. What could cause this? I'm sure I will come up with more questions. Just a little tired right now. |
championgt1 |
Jun 2 2008, 02:50 PM
The previous owner is the one who moved the pump up front at some point. I am starting to think I should locate the pump up front and move it back to its original location. The large line feeds the fuel to the injectors. This is the line the filter was on, and on the filter the flow would be backwards hooked up this way. (IMG:style_emoticons/default/WTF.gif)
I believe the filter was put on to make a junction between the large line coming out of the tunnel to the small line going to the motor. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) The bmw filter you speak of is available at the beemer dealership? |
Lo-Fi Version | Time is now: 28th September 2024 - 09:08 AM |
