> Rear spring spacer, Want to lower my butt
Andyrew
post Jan 1 2004, 06:15 PM
Spooling.... Please wait
I think I have a 1" rear spacer on the bottom of my spring. I would like to take it out to make my car have less rake. My question is how much camber change will 1 in of lowering make? Thanks
Andrew
Brad Roberts
post Jan 1 2004, 09:49 PM
914 Freak!
You will add shims. You have the concept correct about adding them. Somewhere along the line somebody did the math and figured out exactly how much camber was added or taken away with each shim (each shim is /2/3/4 mm depending on what you have now stacked up.
I'm going to bet that your tires will rub more.
B
Andyrew   Rear spring spacer   Jan 1 2004, 06:15 PM
Brad Roberts   Damn good question Andrew :clap: I'm going ...   Jan 1 2004, 06:22 PM
Andyrew   Thanks! I try to figure these things out.. Hm...   Jan 1 2004, 06:29 PM
Andyrew   lazy me   Jan 1 2004, 06:31 PM
Andyrew   more   Jan 1 2004, 06:33 PM
Andyrew   And reason for question havent done much on this ...   Jan 1 2004, 06:39 PM
DNHunt   Man are those oranges on that tree. It sure looks ...   Jan 1 2004, 06:45 PM
Andyrew   Ouch, not much of a football fan, but I can say th...   Jan 1 2004, 06:51 PM
914ghost   May just be the wheel in the gutter, but looks lik...   Jan 1 2004, 06:58 PM
!   Michigan is getting their butts whipped as usual i...   Jan 1 2004, 06:59 PM
Andyrew   Well my main reason for asking this is because of ...   Jan 1 2004, 07:24 PM
Andyrew   Ok, dad checked it and it showed about 1.5 each si...   Jan 1 2004, 08:33 PM
Brad Roberts   RO, Somebody told you to cut the springs ?? LOL U...   Jan 1 2004, 08:38 PM
Andyrew   How will I get camber back when I take the spacer ...   Jan 1 2004, 09:46 PM
ChrisReale   Adding shims gives positive camber, removing creat...   Jan 1 2004, 09:48 PM
Brad Roberts   You will add shims. You have the concept correct a...   Jan 1 2004, 09:49 PM
Andyrew   Right now I aint got no rub.. I dont think I have...   Jan 1 2004, 09:51 PM
Brad Roberts   You will need to take shims with you when you go t...   Jan 1 2004, 09:54 PM
!   Hmmmm, so the rears will go negative when lowered ...   Jan 1 2004, 09:57 PM
Andyrew   I might get some of those.. I sold some of mine to...   Jan 1 2004, 09:58 PM
Gint   Math!?! It's easier to just have the ...   Jan 1 2004, 10:32 PM
Andyrew   Thanks, I will be having the car profesionally ali...   Jan 1 2004, 10:40 PM
Eddie Williams   I have a set of the spacers Brad was talking about...   Jan 1 2004, 10:56 PM
Brad Roberts   Those spacers are actually for the Koni's. The...   Jan 1 2004, 10:59 PM
Bruce Allert   Thanks for posting this question Andrew. Thanks fo...   Jan 2 2004, 12:20 AM
Andyrew     Jan 2 2004, 12:42 AM
Eddie Williams
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 09:37 PM
