> Rear spring spacer, Want to lower my butt
Andyrew
post Jan 1 2004, 06:15 PM
Spooling.... Please wait
I think I have a 1" rear spacer on the bottom of my spring. I would like to take it out to make my car have less rake. My question is how much camber change will 1 in of lowering make? Thanks
Andrew
Joe Bob
post Jan 1 2004, 09:57 PM
Hmmmm, so the rears will go negative when lowered huh? Since Blondie has an issue with rubbing because of the chassis stiffening it....I will have to to put on another 1/4 inch spacer.
What is the minimum number of turns that are recommended on studs to hold a Fuchs on safely? I have that inforation in a race manual somewheres.......in a pile....if I could remember where the pile was..... (IMG:style_emoticons/default/blink.gif)
Oh yeah...adding shims make it go positive right?
Andyrew   Rear spring spacer   Jan 1 2004, 06:15 PM
Brad Roberts   Damn good question Andrew :clap: I'm going ...   Jan 1 2004, 06:22 PM
Andyrew   Thanks! I try to figure these things out.. Hm...   Jan 1 2004, 06:29 PM
Andyrew   lazy me   Jan 1 2004, 06:31 PM
Andyrew   more   Jan 1 2004, 06:33 PM
Andyrew   And reason for question havent done much on this ...   Jan 1 2004, 06:39 PM
DNHunt   Man are those oranges on that tree. It sure looks ...   Jan 1 2004, 06:45 PM
Andyrew   Ouch, not much of a football fan, but I can say th...   Jan 1 2004, 06:51 PM
914ghost   May just be the wheel in the gutter, but looks lik...   Jan 1 2004, 06:58 PM
!   Michigan is getting their butts whipped as usual i...   Jan 1 2004, 06:59 PM
Andyrew   Well my main reason for asking this is because of ...   Jan 1 2004, 07:24 PM
Andyrew   Ok, dad checked it and it showed about 1.5 each si...   Jan 1 2004, 08:33 PM
Brad Roberts   RO, Somebody told you to cut the springs ?? LOL U...   Jan 1 2004, 08:38 PM
Andyrew   How will I get camber back when I take the spacer ...   Jan 1 2004, 09:46 PM
ChrisReale   Adding shims gives positive camber, removing creat...   Jan 1 2004, 09:48 PM
Brad Roberts   You will add shims. You have the concept correct a...   Jan 1 2004, 09:49 PM
Andyrew   Right now I aint got no rub.. I dont think I have...   Jan 1 2004, 09:51 PM
Brad Roberts   You will need to take shims with you when you go t...   Jan 1 2004, 09:54 PM
!   Hmmmm, so the rears will go negative when lowered ...   Jan 1 2004, 09:57 PM
Andyrew   I might get some of those.. I sold some of mine to...   Jan 1 2004, 09:58 PM
Gint   Math!?! It's easier to just have the ...   Jan 1 2004, 10:32 PM
Andyrew   Thanks, I will be having the car profesionally ali...   Jan 1 2004, 10:40 PM
Eddie Williams   I have a set of the spacers Brad was talking about...   Jan 1 2004, 10:56 PM
Brad Roberts   Those spacers are actually for the Koni's. The...   Jan 1 2004, 10:59 PM
Bruce Allert   Thanks for posting this question Andrew. Thanks fo...   Jan 2 2004, 12:20 AM
Andyrew     Jan 2 2004, 12:42 AM
Eddie Williams
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 09:37 PM
