championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
Well I decided to pull the tank after finding out there is no filter up front( pump has been moved up front) and seeing very bad fuel lines up front. Good thing I did, the filter sock was shot to say the least. The area under the tank is in fairly good shap with a few spots of rust and alot of dirt and grime. The rust is not structural which is good.
![]() ![]() I am not sure if this is the first time the tank has been out or not. It is amazing what you will find in the area under the tank besides dirt, grime, and rust.(razor blades, paper towels, washer nozzle, snap-on tool, sanding disk, ect. ect.) Suprisingly the inside of the tank is pretty clean. The outside has a few areas of light rust which I will clean up and paint. ![]() So instead of replacing the filter it will be a little more involved. (While your in there syndrome) My plan is to clean the area under the tank with oil eater, and give it a hot water bath, use some mar-hyde to convert the rust and then paint everthing. This will be my first experience trying to git rid of rust and also painting. I hope it turns out good. Stay tuned for updates and pictures as I progress along. (IMG:style_emoticons/default/bye1.gif) Jack |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
take out your fresh air box and clean out the 30 years of leaves and pineneedles that have accumulated in there ...
(IMG:style_emoticons/default/shades.gif) Andy |
NoEcm |
Member ![]() ![]() Group: Members Posts: 95 Joined: 20-June 05 From: Seattle, WA Member No.: 4,309 ![]() |
take out your fresh air box and clean out the 30 years of leaves and pineneedles that have accumulated in there ... (IMG:style_emoticons/default/shades.gif) Andy If you’re going to do that, repaint the fresh air intake grille back to black. (IMG:http://www.914world.com/bbs2/uploads/post-7420-1213762085_thumb.jpg) |
Lo-Fi Version | Time is now: 29th June 2024 - 04:43 AM |
