> Installing a V-8...a few questions, Progress thread & 914 makeover
computers4kids
post May 28 2008, 10:21 AM
Love these little cars!
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk?
I have the Renegade wiring harness but no diagram...can someone send me a copy?
The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it?
Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy?
I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts.
Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing?
Sorry for all the questions...
Mark
Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins....
LvSteveH
post Jun 21 2008, 03:41 PM
I put the Poor in Porsche
I agree, don't time it by ear.
If you use a piston stop you can establish perfect TDC and mark it under the car. I've marked the balancer (on the bottom) and the flywheel via the hole in the bottom of the trans and either works fine. A timing light with an advance dial makes it easier.
It's annoying to time it under the car, but it works.
To make a piston stop you can take the center out of a spark plug and weld in a bolt with the head cut off. Then round the end so it doesn't damage the piston. You can determine the length with the engine close to TDC then check the depth of the piston through the hole. It will get you pretty close.
Basically you want the length to be just long enough to mark a spot on one side of TDC where the engine won't turn any more. Then spin the engine all the way around and mark the other side of TDC. The center between those two marks will be TDC. Just be careful not to slam the piston into the stop, rotate it slowly.
computers4kids
post Jun 21 2008, 06:09 PM
QUOTE(LvSteveH @ Jun 21 2008, 02:41 PM) *
Thanks...I'm pretty sure I follow your line of thinking. Along that line of thinking, I wonder if this would also work.
Connect my cylinder leakage kit up to #1 and find either side of TDC on the compression stroke. Turn engine one way leakage out of carb (watch meter) intake opens. Turn the other direction...leakage out exhaust (watch meter( exhaust valve opens. Make a mark for both sides of TDC as you mentioned. Divide in half=TDC.
Another option: I could probably watch the valves open and close (#1), mark both sides of TDC and divide in half.
What do you think...am I on the right track?
computers4kids   Installing a V-8...a few questions   May 28 2008, 10:21 AM
michaelt55   Mark; Heres a photo of my radiator setup... I hav...   May 28 2008, 10:50 AM
andys   Mark, If your stock headers have heat shields, I ...   May 28 2008, 10:55 AM
plymouth37   When I worked at Renegade I used rivets to attac...   May 28 2008, 11:06 AM
marks914   Here is how I did my front trunk. Why did I move m...   May 28 2008, 12:00 PM
dbgriffith75   This just blows my mind... I mean, I understand i...   May 28 2008, 02:26 PM
plymouth37   Is there a lot of butchering that has to be done?...   May 28 2008, 02:38 PM
marks914   This just blows my mind... I mean, I understand ...   May 28 2008, 09:01 PM
cobra94563   Stock location is fine if tray is solid. Something...   May 28 2008, 02:44 PM
dbgriffith75   I don't know about easy to maintain... don...   May 29 2008, 08:31 AM
computers4kids   Are joo sure? :D There is more room to work ...   May 29 2008, 08:41 AM
computers4kids   The exhaust is headers with twin turbo exhaust. ...   May 29 2008, 08:57 AM
dakotaewing   Here are some pics I have of various cars...   May 29 2008, 08:59 AM
michaelt55   Here are some pics I have of various cars... H...   May 29 2008, 10:47 AM
wes42   I just saw your thread.....Good Luck with your ins...   May 29 2008, 09:21 AM
wes42   I just saw your thread.....Good Luck with your in...   May 29 2008, 09:29 AM
wes42   [quote name='wes42' post='1038074' date='May 29 2...   May 29 2008, 09:31 AM
turboman808   Oh man that is so sick.   Jun 12 2008, 12:24 AM
dakotaewing   MAS   May 29 2008, 09:37 AM
plymouth37   Here is my front end. With Renegades lower valence...   May 29 2008, 11:48 AM
michaelt55   Just a question...are those jackstands sitting on ...   May 29 2008, 12:47 PM
jimkelly   throttle cables - what are you guys using - stock ...   May 29 2008, 04:57 PM
marks914   Here is mine, an extended terry cable, it came wit...   May 29 2008, 05:15 PM
cobra94563   I currently using the STOCK throttle cable pulling...   May 29 2008, 07:11 PM
computers4kids   Well, I came home tonight after work and felt like...   May 29 2008, 11:38 PM
jmmotorsports   Well, I came home tonight after work and felt lik...   May 30 2008, 08:51 AM
plymouth37   If I remember correctly the gasket you need is off...   May 29 2008, 11:50 PM
BIGKAT_83   The stock cable works fine if mounted correct. I d...   May 30 2008, 02:05 PM
computers4kids   More progress...installed exhaust, prepped the fro...   Jun 1 2008, 10:04 AM
computers4kids   After cooking breakfast and some family time...I h...   Jun 2 2008, 12:45 AM
computers4kids   radiator lines & front trunk compartment (gas ...   Jun 2 2008, 12:46 AM
rhodyguy   which one of the cars in your signature is that? n...   Jun 2 2008, 12:55 AM
computers4kids   which one of the cars in your signature is that? ...   Jun 2 2008, 01:15 AM
rhodyguy   does your engine require premium fuel? nice to hav...   Jun 2 2008, 01:19 AM
computers4kids   does your engine require premium fuel? nice to ha...   Jun 2 2008, 08:21 AM
computers4kids   Moving along... Took all the brakes off and gettin...   Jun 5 2008, 09:03 AM
JRust   Don't ruin a nice early front bumper! Find...   Jun 6 2008, 09:47 AM
computers4kids   Don't ruin a nice early front bumper! Fin...   Jun 9 2008, 05:52 PM
JRust   Don't ruin a nice early front bumper! Fi...   Jun 9 2008, 09:53 PM
computers4kids   A little more progress today...the focus was bumpe...   Jun 10 2008, 09:26 PM
JRust   Looking good Mark! What color are you planning...   Jun 10 2008, 10:19 PM
TC 914-8   Lots of great pictures, I have a Rod Simpsin kit a...   Jun 11 2008, 01:18 AM
TC 914-8   I re-ran the factory cable from two tight turns in...   Jun 11 2008, 01:31 AM
computers4kids   I re-ran the factory cable from two tight turns i...   Jun 11 2008, 08:33 AM
Jeffs9146   This is my favorite V8 conversion and it shows t...   Jun 11 2008, 07:41 AM
computers4kids   Today I started installing the Renegade wiring har...   Jun 11 2008, 10:23 PM
computers4kids   last question   Jun 11 2008, 10:23 PM
cobra94563   your progress is much faster That I ever got thing...   Jun 12 2008, 01:05 AM
JRust   Mark is kind of like diaria with his car. You hold...   Jun 12 2008, 02:34 PM
jimkelly   got a custom cable from terry cable - 18 inches lo...   Jun 12 2008, 03:20 PM
computers4kids   The latest... I removed the support brace from the...   Jun 18 2008, 08:53 AM
computers4kids   In the engine compartment I added a wide mesh stee...   Jun 18 2008, 08:55 AM
computers4kids   The steel bumpers were off my 74, so I went ahead ...   Jun 18 2008, 08:59 AM
rhodyguy   it'll look swell. that's one slick carb th...   Jun 18 2008, 09:06 AM
computers4kids   Well, the saga continues... Brakes are all bled an...   Jun 20 2008, 08:26 AM
computers4kids   The previous owner of my project car is/was a bit ...   Jun 21 2008, 11:47 AM
jimkelly   make sure your brakes work - stock or 911 - make s...   Jun 21 2008, 02:17 PM
computers4kids   make sure your brakes work - stock or 911 - make ...   Jun 21 2008, 05:48 PM
JRust   Just pull the drivtrain & time it out of the c...   Jun 21 2008, 02:32 PM
computers4kids   Just pull the drivtrain & time it out of the ...   Jun 21 2008, 05:51 PM
LvSteveH   I agree, don't time it by ear. If you use a ...   Jun 21 2008, 03:41 PM
computers4kids   If you use a piston stop you can establish perfec...   Jun 21 2008, 06:09 PM
Dr. Roger   <What do you think...am I on the right track?...   Jun 21 2008, 10:13 PM
Dr. Roger   applicable thread... http://www.914world.com/bbs2...   Jun 21 2008, 10:18 PM
computers4kids   applicable thread... http://www.914world.com/bbs...   Jun 22 2008, 12:14 AM
computers4kids   The car can now be timed from the driver's whe...   Jun 22 2008, 02:39 PM
computers4kids   More progress... Today, I painted the interior ...   Jun 29 2008, 11:38 PM
computers4kids   I've begun installing the interior of the car....   Jul 2 2008, 11:21 PM
JRust   Looking good Mark! I got your air cleaner out ...   Jul 3 2008, 01:16 AM
computers4kids   Doors went back on today...alignment was a piece o...   Jul 4 2008, 12:16 AM
Dr. Roger   Momentum is building. the end is in sight. :Qa...   Jul 4 2008, 12:31 AM
computers4kids   Momentum is building. the end is in sight. :Q...   Jul 4 2008, 01:24 AM
JRust   I've got a rear valance that would work. It is...   Jul 4 2008, 01:49 AM
computers4kids   I've got a rear valance that would work. It i...   Jul 4 2008, 12:30 PM
type47fan   Lookin' good, Mark. I modified a '72 vala...   Jul 5 2008, 12:30 AM
computers4kids   Let's see... Installed the rest of interior li...   Jul 7 2008, 06:18 PM
computers4kids   Well, took a couple of weeks off and travled up to...   Jul 18 2008, 09:34 PM
JRust   I kind of like the flatter & wider ovaled pipe...   Jul 19 2008, 02:17 PM
computers4kids   Installing the ghetty dash took much longer than I...   Jul 20 2008, 09:40 PM
JRust   Yes just pull the cover & loosen the one bolt....   Jul 20 2008, 09:59 PM
computers4kids   It's official...the 75 is off its rollers. I ...   Jul 21 2008, 09:52 PM
JRust   Absolutely sweeeeeeeet! :driving: :headbanger...   Jul 21 2008, 10:16 PM
computers4kids   Absolutely sweeeeeeeet! :driving: :headbange...   Jul 21 2008, 11:39 PM
neo914-6   :beer2: great job! :driving:   Jul 22 2008, 04:02 AM
michaelt55   Great looking car! I love the interior and wo...   Jul 22 2008, 03:50 PM
computers4kids   Great looking car! I love the interior and w...   Jul 22 2008, 09:24 PM
JRust   Although I have not ridden in Mark's I will go...   Jul 22 2008, 08:55 PM
computers4kids   I blew a... What did you blow? This is a family...   Jul 22 2008, 09:19 PM
JRust   I blew a... What did you blow? This is a famil...   Jul 22 2008, 11:40 PM
Wilhelm   [quote name='computers4kids' post='1059580' date=...   Jul 26 2008, 05:53 AM
computers4kids   Now I know why GT grills are so expensive...they...   Jul 23 2008, 12:48 AM
TC 914-8   Mark, Great install and progress thread. Some d...   Jul 26 2008, 12:21 AM
computers4kids   Mark, Great install and progress thread. Some ...   Jul 26 2008, 12:40 AM
computers4kids   Back to our regular scheduled program... Added som...   Jul 26 2008, 12:43 AM
michaelt55   "Added some Camp914 bling to the cabin today....   Jul 30 2008, 05:00 PM
computers4kids   Also in the mail today from Craig, came the beadin...   Jul 26 2008, 12:47 AM
computers4kids   Thanks to Nick, his almost new BMW front calipers ...   Jul 29 2008, 11:34 PM
computers4kids   A little more progress... I took...no, "I dro...   Aug 1 2008, 06:12 PM
computers4kids   After the muffler shop, drove it down to this high...   Aug 1 2008, 06:38 PM
JRust   Sounds good Mark! Dual tips fill it perfectly....   Aug 2 2008, 12:30 AM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 3rd April 2025 - 01:23 AM
