FI fuel line routing |
watsonrx13 |
Jun 30 2008, 06:00 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I'm in the process of installing AA's upper fuel line kit, but I'm not certain how the long FI fuel line goes across the engine from one side to the other.
Here's how I've placed it, is this the correct location? Also, I need some assistance with the wires.... I have a red wire coming from the Aux Air Valve, where does it connect to? I also have a white wire from the wiring loom, does it connect to the white wire at the quick connect, next to the distributor? Also, where does the black wire from the distributor connect to? Finally, do I have the distributor wired correctly and should the spark plug wires go beneath the intake manifolds? -- Rob |
watsonrx13 |
Jun 30 2008, 06:33 PM
Thanks Paul.... The white wire was connected to the thermo switch, but I thought maybe it was wired wrong because there's a white wire, with the quick-connect, coming out of the wiring harness, next to the distributor.... I guess the red wire connects here?
I'll definately run the fuel line behind the dist and oil filler... Did you tie-wrap this fuel line to anything? -- Rob |
Lo-Fi Version | Time is now: 25th September 2024 - 10:45 PM |
