FI fuel line routing |
watsonrx13 |
Jun 30 2008, 06:00 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I'm in the process of installing AA's upper fuel line kit, but I'm not certain how the long FI fuel line goes across the engine from one side to the other.
Here's how I've placed it, is this the correct location? Also, I need some assistance with the wires.... I have a red wire coming from the Aux Air Valve, where does it connect to? I also have a white wire from the wiring loom, does it connect to the white wire at the quick connect, next to the distributor? Also, where does the black wire from the distributor connect to? Finally, do I have the distributor wired correctly and should the spark plug wires go beneath the intake manifolds? -- Rob |
AvalonFal |
Jul 1 2008, 08:57 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Rob:
Yes, the red AAR wire to the white wire in the plastic connector and the other white wire to the Thermoswitch. There's a lot going on behind the oil fill and distributor so I just tucked the fuel line down under the air box edge and the AAR and out of the way. It's a straight run across to the other fuel rail. I ran the plug wires under the tubes for cylinders #1 & #3 because I think it looks better, but I've seen them on top, too. There should be wire holders behind the oil fill and on the tin top near the coil to help route the wires. Paul |
Lo-Fi Version | Time is now: 24th June 2024 - 07:41 AM |
