watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I'm in the process of installing AA's upper fuel line kit, but I'm not certain how the long FI fuel line goes across the engine from one side to the other.
Here's how I've placed it, is this the correct location? ![]() Also, I need some assistance with the wires.... I have a red wire coming from the Aux Air Valve, where does it connect to? I also have a white wire from the wiring loom, does it connect to the white wire at the quick connect, next to the distributor? Also, where does the black wire from the distributor connect to? ![]() Finally, do I have the distributor wired correctly and should the spark plug wires go beneath the intake manifolds? ![]() -- Rob |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Your 74 throttle body has only one vac line nipple (emissions thing). Plug the nipple on the diz, or drill the boss on the throttle body for the nipple. The factory (so I am told) just tucked the line under the plenum. Adding the nipple and hooking up the line will give a noticed difference in low end throttle response (did for me anyway).
watsonrx13 |
Your 74 throttle body has only one vac line nipple (emissions thing). Plug the nipple on the diz, or drill the boss on the throttle body for the nipple. The factory (so I am told) just tucked the line under the plenum. Adding the nipple and hooking up the line will give a noticed difference in low end throttle response (did for me anyway). Curt, do you have a pic or describe which part of the plenum you attached it to? I do have a hole on the horizontal section of the throttle body/plenum, similar to the yellow hose from the MPS.... If I find a small section of metal tubing, I guess I could put this in the plenum then attach this hose to it, correct? -- Rob |
Lo-Fi Version | Time is now: 24th June 2024 - 06:58 AM |
