Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
A little history first...
This is my third 914 and it will be a keeper. First two are from my college days in the late 1980's but both of those are gone (1st was totalled in a crash, the second had terminal rust and eventually became a parts car) Fast forward roughly 20 years. Got married, had two kids and I decided I could not continue to put off building my dream car. While I had always wanted an original 914/6, I also wanted a general purpose fun car (Street, Autocross and Track) that would have had more power and safety features than a stock 914/6. I can't afford to have multiple 914s (a stock 914/4, a 914/4 with a modern Type IV, a stock 914/6, a 914/6 GT Clone, a track only 914, etc.), so rather than molest a "real" 914/6 to build my dream "six", I decided to start with a regular 914/4 and do a six swap. This car was purchased in 8/2005. Over the past two years I have disassembled the entire car and am now at the point of doing repair and refurbishment. Which is why I picked now as the time to do the progress thread (who wants to read about the dis-assembly of a car!) Goals for the car...
I have my own website that contains a higher level of detail on specific sections of the car as well as a more detailed general Blog. I currently host this at home and sometimes the server is down, but it is up most of the time. You can find that here... http://motorsport.zyyz.com/project_914.htm |
Richard Casto |
Here I am starting a test to see what is the best way to clean and protect magnesium parts. With a target of trying to replicate what the factor did, but with easy to find supplies. The factory wants you to clean with "Stoddard Solvent" which is a type of mineral spirits. For coatings, it appears they did a chromate conversion to protect the parts during manufacturing (post casting and machining) and then follow that up (post assembly) with "Tectyl" which is a waxy coating. Chromate conversion is not easy to do at home due to environmental issues and Tectyl is nearly impossible to obtain in small quantities.
My cleaners are... A. Soap and Water (dish soap) B. Simple Green (straight) C. Mineral Spirits D. Glass Bead Blasting My coatings are... W. Nothing (unprotected) X. Gibbs Brand Penetrating Oil/Lubricant Y. CRC Heavy Duty Corrosion Inhibitor Z. Gibbs + CRC My test part is the magnesium differential cover from a 914 transmission. The cast in webbing naturally segments the part into 10 sections. Starting with #1 being the most upper right segment, I numbed them 1-10 in a clockwise fashion. ![]() Here is the outside after coating. Here is the key for the segments... 1. B, W 2. B, W 3. B, Y 4. B, X 5. B, Z 6. C, Z 7. C, X 8. C, Y 9. C, W 10 C, W ![]() Here is the inside after coating. Here is the key for the segments... 1. D, W 2. D, W 3. D, Y 4. D, X 5. D, Z 6. A, Z 7. A, X 8. A, Y 9. A, W 10. A, W I am going to let this weather outside and see what works the best. |
Lo-Fi Version | Time is now: 6th April 2025 - 03:29 PM |
