Inline remote oil filters, scavenge side |
iamchappy |
Jul 11 2008, 10:30 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I am installing a Canton remote oil filter in between my oil tank and the engine scavenge inlet. I am doing this to eliminate the possibility of metal particles that have showed up in the past on the sump screen. There may have been some lurking in the tank or lines that never flushed out.
? what size filter would be adequate to filter and not hinder oil flow, a fine element 8-micron or a fine 140 mesh 150 micron screen, the oil pump is a turbo pump. |
iamchappy |
Jul 13 2008, 11:51 AM
They didn't it is still a ? mark.
The only thing i can think of is it may of been in there from past history before i owned the car. The Canton inline scavenge filter i have is made for the suction side of a dry sump and would not be restricting the screen element is much like the screen on a sump. The problem with the stock filter and the stock engine thermostat as i understand is they have an oil bypass so the oil is not always getting filtered, so if i added the Cantan canister filter in the pressure side out of the engine i would be assured that all the oil is getting filtered all of the time. |
J P Stein |
Jul 13 2008, 04:21 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
They didn't it is still a ? mark. The only thing i can think of is it may of been in there from past history before i owned the car. The Canton inline scavenge filter i have is made for the suction side of a dry sump and would not be restricting the screen element is much like the screen on a sump. The problem with the stock filter and the stock engine thermostat as i understand is they have an oil bypass so the oil is not always getting filtered, so if i added the Cantan canister filter in the pressure side out of the engine i would be assured that all the oil is getting filtered all of the time. As I understand it, the only time a proper filter will bypass is if it is clogged. Regular replacement will keep that from happening....unless the bearings & other implements self destruct, then it becomes moot. That said, another filter won't hurt either....unless it becomes clogged. |
Lo-Fi Version | Time is now: 25th June 2024 - 04:50 PM |
