> 914 brake question
honlude
post Jul 13 2008, 03:31 PM
Hello
i am working on my 1975 914 1.8 , i rebuilt the master cyl , rebuilt right rear caliper , and replaced left rear caliper , replace the grommets on master cyl for resov. lines , i have set the rear brake venting to .008 and bleed the system multiple time , i have no air coming thru system at all , i have brakes now but they just dont seem to be correct , if i stand on the brakes hard they do not lock up while driving, are the brakes on these just that way or dose anyone have any other suggestions on what could be a problem , ... i have no leaks anywhere either and the park brake seems to hold the car under a light load
thanks craig
McMark
post Jul 14 2008, 10:41 PM
914 Freak!
I have no doubt that you still have air in your lines. A stock system should have a nice firm pedal. You should definitely be able to lock up the tires with any pads. I find on most 914s that I have to bleed, drive, bleed, drive, bleed some more. It's a MAJOR PITA! But something about getting the car out and using the brakes frees up more bubbles. BTW, I'm not talking about a long drive here. Just up and down the block. BE SAFE!
Did you bench bleed the M/C before you installed it? The M/C is a PITA to get all of the air out of. The Prop Valve is a PITA to get all of the air out of. You're not clear yet. Search for posts describing the long tube bleeding method. There is one by Trekkor and I think SirAndy has one in his 3.6 build thread.
Anyone who disses the stock system* has not had a completely correct system.
*motors larger than stock, or cars used on a large racetrack can complain about the stock system.
honlude   914 brake question   Jul 13 2008, 03:31 PM
3d914   If its the stock master cylinder - that may just b...   Jul 13 2008, 04:16 PM
wilchek   Sounds like you did what you should have. The bra...   Jul 13 2008, 04:23 PM
Phoenix 914-6GT   When I had my 4 I had stock pads in there that was...   Jul 13 2008, 04:34 PM
ClayPerrine   Hello i am working on my 1975 914 1.8 , i rebu...   Jul 13 2008, 08:46 PM
honlude   thanks for all the help i have replaced the rear ...   Jul 14 2008, 07:32 AM
wilchek   should be 10mm but don't quote me on that. Yo...   Jul 14 2008, 07:56 AM
davep   These brake lines are 10mm by 1.0 pitch.   Jul 14 2008, 07:58 AM
Cap'n Krusty   I dunno if you read the earlier post about the ven...   Jul 14 2008, 09:31 AM
Vacca Rabite   If you want it, I have a NIB spare ATE 19mm MC, an...   Jul 14 2008, 10:02 AM
honlude   thanks guys i will def go out today and double che...   Jul 14 2008, 11:13 AM
McMark   I have no doubt that you still have air in your li...   Jul 14 2008, 10:41 PM
honlude   Hey i just wanted to thank everyone for there hel...   Jul 20 2008, 01:23 PM
Wanna9146   Hey i just wanted to thank everyone for there he...   Jul 20 2008, 01:29 PM
jetboy   Hey i just wanted to thank everyone for there h...   Jul 20 2008, 01:52 PM
Eric_Shea   http://www.914world.com/bbs2/index.php?showtopic=8...   Jul 20 2008, 02:20 PM
Wanna9146   http://www.914world.com/bbs2/index.php?showtopic=...   Jul 20 2008, 02:27 PM
Eric_Shea   Excellent! There's still a lot of good in...   Jul 20 2008, 04:13 PM
- Lo-Fi Version Time is now: 28th December 2024 - 01:34 AM
