> Swapping proportioning valve for "T" fitting...
Wanna9146
post Jul 14 2008, 10:10 PM
I read on this forum recently about someone swapping out their proportioning valve for a "T" fitting.
Does anyone know the size/thread count of the correct "T" fitting? Any fabrication required?
Krieger
post Jul 14 2008, 10:51 PM
QUOTE(smg914 @ Jul 14 2008, 09:47 PM) *
You can also purchase the same "T" fitting at your local VW parts and accessories store for about half the price of the Porsche dealer. The last time I purchased one at a VW store I paid $7.00 for it.
I upgraded front brakes to BWM calipers and did this mod about 6 years ago. The originak reg is still in a zip lock.
Wanna9146
post Jul 14 2008, 10:55 PM
QUOTE(Krieger914 @ Jul 14 2008, 08:51 PM) *
I don't need to do the BMW caliper conversion for this to work, right?
Wanna9146   Swapping proportioning valve for "T" fitting...   Jul 14 2008, 10:10 PM
ClayPerrine   I read on this forum recently about someone swapp...   Jul 14 2008, 10:34 PM
smg914   You can also purchase the same "T" fitti...   Jul 14 2008, 10:47 PM
Krieger914   You can also purchase the same "T" fitt...   Jul 14 2008, 10:51 PM
Wanna9146   I upgraded front brakes to BWM calipers and did ...   Jul 14 2008, 10:55 PM
r_towle   I upgraded front brakes to BWM calipers and did...   Jul 15 2008, 09:25 AM
Wanna9146   The stock system is designed very well, and the Pr...   Jul 15 2008, 09:50 AM
Wanna9146   Would it be P/N 914.355.667.00 ?   Jul 14 2008, 10:54 PM
904svo   Where at in Ga. do you live? I have a spare T you ...   Jul 15 2008, 08:53 AM
Wanna9146   Where at in Ga. do you live? I have a spare T you...   Jul 15 2008, 09:48 AM
904svo   Where at in Ga. do you live? I have a spare T yo...   Jul 15 2008, 10:08 AM
Wanna9146   This T fitting was located in the front brake cir...   Jul 15 2008, 10:10 AM
brant   have fun spinning off the road backwards into the ...   Jul 15 2008, 09:43 AM
Wanna9146   have fun spinning off the road backwards into the...   Jul 15 2008, 09:51 AM
brant   have fun spinning off the road backwards into th...   Jul 15 2008, 11:01 PM
rhodyguy   i've never quite understood the reasoning for ...   Jul 15 2008, 09:54 AM
Wanna9146   i've never quite understood the reasoning for...   Jul 15 2008, 09:56 AM
rhodyguy   ok. what do you figure a known good used valve cos...   Jul 15 2008, 10:02 AM
Wanna9146   ok. what do you figure a known good used valve co...   Jul 15 2008, 10:06 AM
Wanna9146   ok. what do you figure a known good used valve co...   Jul 15 2008, 10:23 AM
rhodyguy   happy motoring. k   Jul 15 2008, 10:09 AM
Wanna9146   happy motoring. k If I do this swap, I'll ...   Jul 15 2008, 10:13 AM
SirAndy   Anyone taking bets that the car won't stop in...   Jul 15 2008, 01:19 PM
Wanna9146   Anyone taking bets that the car won't stop i...   Jul 15 2008, 08:15 PM
r_towle   The proportioning valve is really a simple piston ...   Jul 15 2008, 10:29 AM
Wanna9146   The proportioning valve is really a simple piston...   Jul 15 2008, 10:37 AM
davesprinkle   The proportioning valve is really a simple piston...   Jul 16 2008, 09:27 AM
brant   its emergency situations when the brakes will surp...   Jul 15 2008, 12:08 PM
sww914   I wouldn't automatically blame the proportioni...   Jul 15 2008, 12:55 PM
Wanna9146   I wouldn't automatically blame the proportion...   Jul 15 2008, 08:13 PM
sww914   I wouldn't automatically blame the proportio...   Jul 15 2008, 08:23 PM
r_towle   The pedal is beyond "spongy". It goes a...   Jul 15 2008, 08:25 PM
Wanna9146   Thanks, I'll give this a shot. BUT Try this ...   Jul 15 2008, 09:25 PM
Lavanaut   People here are trying to help you out with real, ...   Jul 15 2008, 01:22 PM
jmill   After doing quite a bit of research on this topic ...   Jul 15 2008, 01:40 PM
Eric_Shea   Make sure your steering wheel is straight otherw...   Jul 15 2008, 08:41 PM
Wanna9146   Thanks Eric, but don't worry about the "T...   Jul 15 2008, 09:14 PM
Cap'n Krusty   Spongy brakes after rebuilding the calipers is a p...   Jul 15 2008, 09:02 PM
Wanna9146   If you go back and read, I only responded negative...   Jul 15 2008, 09:16 PM
904svo   Read this, It will explain the problems if you ins...   Jul 15 2008, 09:58 PM
Eric_Shea   Man I wish that article would go away but... it wo...   Jul 15 2008, 10:29 PM
70Sixter   Eric and brant both mentioned tapping on the p-val...   Jul 16 2008, 09:31 AM
rhodyguy   the adj valve is a SUPER idea! :headbanger: b...   Jul 16 2008, 09:41 AM
roadster fan   the adj valve is a SUPER idea! :headbanger: ...   Jul 16 2008, 03:37 PM
Eric_Shea   Dave, did you get it working the way you'd lik...   Jul 16 2008, 10:22 AM
SlackeR32   I don't mean to hijack, but since everyone is ...   Jul 16 2008, 10:32 AM
Phoenix 914-6GT   I have a T fiting in mine. What should I have? I...   Jul 16 2008, 06:19 PM
Eric_Shea   You have what are called "Wide A-Calipers...   Jul 16 2008, 08:11 PM
davesprinkle   (...lots of insightful braking stuff truncated h...   Jul 17 2008, 10:26 AM
SlackeR32   Thank you Eric! I was a bit confused at fir...   Jul 17 2008, 01:03 PM
6freak   You have what are called "Wide A-Calipers...   Jul 17 2008, 02:06 PM
Eric_Shea   The threaded adjust rod simply rests against a h...   Jul 17 2008, 07:34 PM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 05:49 PM
