Swapping proportioning valve for "T" fitting... |
Wanna9146 |
Jul 14 2008, 10:10 PM
Member Group: Members Posts: 235 Joined: 19-January 08 From: Florida Member No.: 8,595 Region Association: South East States |
I read on this forum recently about someone swapping out their proportioning valve for a "T" fitting.
Does anyone know the size/thread count of the correct "T" fitting? Any fabrication required? |
sww914 |
Jul 15 2008, 12:55 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I wouldn't automatically blame the proportioning valve yet. If you've just rebuilt the calipers, replaced the pads, and turned the rotors, you will often have a somewhat spongy pedal for a while. The pads and the rotors are not yet making full contact on their faces because they need to wear into each other a bit, and the caliper pistons will need to smash through the paint and/or insulating material on the back of the pads. The just replaced calipers may also not be sitting perfectly true and square due to little bits of grit or corrosion on the mounting surfaces, but they will work their way into a solid position after some use.
Also, you didn't mention having gone through the fun process of adjusting the air gap on the rear pads for the parking brake, if that's maladjusted it will give you a long pedal. If the pistons in the calipers are clocked at the wrong angle, the high part of the lip on the piston will push more on one side of the pads than the other, as it's designed to, but in the wrong spot, thus wearing the pads unevenly. This should be corrected as it will shorten pad life significantly and it will take longer to get a firm pedal until the pads have worn flat to the rotors which would be at an odd angle in relation to the brake pad backing plate. As you can see, there are several potential problems that a tee won't address. |
Wanna9146 |
Jul 15 2008, 08:13 PM
I wouldn't automatically blame the proportioning valve yet. If you've just rebuilt the calipers, replaced the pads, and turned the rotors, you will often have a somewhat spongy pedal for a while. The pads and the rotors are not yet making full contact on their faces because they need to wear into each other a bit, and the caliper pistons will need to smash through the paint and/or insulating material on the back of the pads. The just replaced calipers may also not be sitting perfectly true and square due to little bits of grit or corrosion on the mounting surfaces, but they will work their way into a solid position after some use. Also, you didn't mention having gone through the fun process of adjusting the air gap on the rear pads for the parking brake, if that's maladjusted it will give you a long pedal. If the pistons in the calipers are clocked at the wrong angle, the high part of the lip on the piston will push more on one side of the pads than the other, as it's designed to, but in the wrong spot, thus wearing the pads unevenly. This should be corrected as it will shorten pad life significantly and it will take longer to get a firm pedal until the pads have worn flat to the rotors which would be at an odd angle in relation to the brake pad backing plate. As you can see, there are several potential problems that a tee won't address. The pedal is beyond "spongy". It goes almost to the floor. The car will only stop after some pumping and there is no way it will lock-up the brakes for a sudden stop. I'll dismantle the proportioning valve and inspect/clean. That's really the only thing left that hasn't been addressed. Perhaps it is preventing a full bleed...? |
Lo-Fi Version | Time is now: 26th December 2024 - 05:46 PM |
