3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
I've been assembling all the parts to re-install heat in my teener, and now I'm down to checking out all the wiring. But I'm not getting any power to the rear heater fan (in engine bay).
I've cleaned up the connectors and wiring from the heater switch behind the shifter (ground side of the circuit). It comes out at pin #9 on the forward 14-pin connector on the relay board. Power should be going to pin #11 of the same connector, but Im gettin zip. This #11 connects to pin #10 of the lower-right 12-pin connector on the relay board - which bridges to pin #11 - then over to #87 of the relay. I'm getting power at #30 on the relay - but don't have a way to check where its going from there. The relay is new, and I've swapped with others - but keep ending up with no power. Any ideas - what I might be missing? TIA, |
3d914 |
Brad,
You may be one of those who have a lever that happens to touch the mounting bracket when up - which then could close the ground circuit. THe two that I tested - One touched & the other didn't, but neither one completed the ground circuit. I'm just shootin in the dark here with testing as I have not found any hard data on how this is supposed to work. Somebody straighten me out here. PS: I like your anti-theft device! Have you ever bumped it while driving? |
Lo-Fi Version | Time is now: 26th June 2024 - 03:49 AM |
