Accelerator will not return to idle |
tornik550 |
Jul 17 2008, 09:24 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have weber 40 idf carbs with a bugpack linkage. Is there supposed to be a spring on the accelerator pedal that returns the pedal idle or are the springs on the carbs the only springs to return the pedal to idle?
Thanks again- Steve |
rebelmdot |
Jul 17 2008, 09:40 PM
914ini Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States |
Spring on Carb is the only one. I had similar problem and had to get a heavy duty spring to accomplish the idle release that I wanted. If you want, I can take a picture of what I did.
tornik550 |
Jul 18 2008, 07:29 AM
Spring on Carb is the only one. I had similar problem and had to get a heavy duty spring to accomplish the idle release that I wanted. If you want, I can take a picture of what I did. Thank you for your response. If it is not too much of a problem, would you mind taking a pic of the springs? The springs that come with the kit are very wimpy. |
Lo-Fi Version | Time is now: 27th December 2024 - 02:03 AM |
